121 Views 5 Replies Latest reply: Feb 20, 2013 5:47 PM by silverhead RSS
mjs367 Just Startin' 2 posts since
Jan 4, 2013
Feb 16, 2013 2:18 AM
Can we convert tones to make them HD500 compatible?
Got my HD500 at Christmas. When I search for certain bands / artists on Customtone the selection seems a bit limited. Just for example - a search on Peter Buck / REM give 19 results on other products... but zero on the HD500. Is there anyway to convert these to make them compatible?
  • medbad5150 Just Startin' 53 posts since
    Jun 28, 2007
  • silverhead Expert Line 6 User 9,592 posts since
    Apr 1, 2009
    Feb 16, 2013 4:15 AM (in response to mjs367)
    Re: Can we convert tones to make them HD500 compatible?
    The conversion utility above only works among Pod HD products. There is no way (other than manual recreation) to convert setlists from earlier products to any of the Pod HD models.
    • Currently Being Moderated
      Feb 20, 2013 8:49 AM (in response to mjs367)
      I think if someone has enough time, it could be possible to reverse engineer old fileformats like Zab did it for new (HD line) formats and then to make some utility to convert it to newer formats (with limitations regarding different amps, different effect settings, etc), but I think you won't find anyone to do so. It would be really time consuming because of number of older Line6 gear (POD 2.0, XT, X3, PODfarms etc.) and also to figure out how to exactly translate older settings to sound right with HD series...
        Apr 1, 2009
        Feb 20, 2013 5:47 PM (in response to JanKupsa)
        I don't think this would be practical. Quite apart from the amount of effort involved to deal with the many previous products and their various amp models, the biggest problem would be dealiong with the fact that the HD series is advertised as being a 10-fold improvement in  terms of sampling detail. In other words, a conversion would have to map each bit of information into 10 bits - with absolutely no information about how to do the mapping. Imagine handling two consecutive bits of X3 information with values 1 and 2, and having to assign 10 interim values within the range. Would you assign them linearly (1.0, 1.1, 1.2, 1.3,...1.9, 2.0)? Or would you use some other algorithm (e.g. 1.0, 1.0, ...1.5, 1.5, 2.0)? No matter what you do, the result in HD terms would probably sound very different from the actual HD modeling sounds. I think it's an admirable idea, but an impractical one.
        Or, to use perhaps a more familiar analogy, imagine taking a photo with your digital camera at a low resolution intended for sharing via email. That's the X3. Now imagine you want to print that photo in a 10x14 portrait. The resolution is going to be blurry, and there's nothing you can do about it because the detailed clarity simply does not exist in the data. On the other hand, if you had originally taken the photo in a hi-res format (the Pod HD) a 10x14 printout would look great, with much more visual detail and clarity.
        The reason that conversion works among the Pod HD products is that they all use the same modeling technology, and the underlying data resolution is the same. It's really just a difference in mapping inputs and outputs as well as filenames, with a few manageable variances in FX options.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
