Feb 21, 2013 7:50 AM
Help with distorted/overdriven sound using variax setting
Like (0)
On some patches...utilizing the Variax, the sound is very distorted (not a good distorted) almost like it's overdriving the PA...muffled, distorted etc..... I swich to the mags and it cleans up.
Any ideas what the issue is or what I can change in that setting to correct this?
Does it do with every modeled guitars (tele, strats, les paul) on that particular patches or only lets say les pauls? These patches might have been made for guitar with "low gain" pickups and to compensate this, authors could put let's say some compresors (or eq with higher gain) to compensate this. Does it also do when you lower modeled guitar volume using volume pod on Variax?
I will try that and get back to you. Maybe it's just doing it on the acoustic models
The magnetic pickups - at least on the JTV-69, but it sounds like the JTV-59 as well - have a lower output than the modelling circuit, at least at their standard heights. So it's likely hitting the front of the patch too hard when using the models as compared to the mags. The fix most people seem to have for this is lowering the output of the guitar models in Workbench to more closely match the magnetic pickups.
is that model specific or can it be preset specific?
Unfortunately, it's global with the current Workbench. Maybe? the new version of WB coming with the new JTV-HD 2.0 update will allow model specific volume changes but there's not even a rumor of that - just wishful thinking on my part.
If you are using your JTV with the HD500, it could be something as simple as accidentally saving the patch with the tone turned down. I've done that several times during rehearsals and didn't figure out the problem until I got back home to work it out. So when you turn off the modelling and go with the mag pickups it sounds good. If then after switching the modelling back on it sounds muffled and bassy -- adjust the tone knob on your JTV -- problem solved.
