110 Views 2 Replies Latest reply: Feb 28, 2013 8:36 AM by sdevino RSS
Ragey Just Startin' 1 posts since
Oct 22, 2010
Feb 21, 2013 5:36 PM
Relay G90 XLR Output VS. 1/4" Jack Output Questions
Greetings
I've got a few questions.
I've owned the G90 for about 2 years now.
Since ownership, I've always noticed a considerable dip in signal gain when running the G90 Receiver Output from the 1/4" Jack, and it's been putting me off using the unit.
I've tried wiring up better 1/4" cables, that are shorter (as it's housed in a rack and running straight into an RJM RG16 about a foot away.
However, last night I tried running an XLR > 1/4", and using the XLR output, and bob's your uncle. The signal gain was perfect.
As far as I'm aware, and XLR Mic cable is a hotter signal than 1/4" instrument cable, hence why I tried it.
However, should this be happening? Is it possible the 1/4" Jack output has malfunctioned in some way?
Or is this perfectly normal. If so, I'll just wire up a good quality Neutrik Gold pin female XLR to Neutrik Gold 1/4" jack in balanced mono using Canare Mic Cable.
Is it fine to run XLR Mic cable to 1/4" Jack mono balanced?
Cheers
  • dboomer Line 6 Support 1,997 posts since
    Oct 13, 2008
    Feb 22, 2013 11:15 AM (in response to Ragey)
    Re: Relay G90 XLR Output VS. 1/4" Jack Output Questions
    The output is the same level at either jack.  However if you are running from the balanced XLR jack to an unbalanced input then you will lose 6 dB over what you would get into a balanced input.  Our 1/4" jack is unbalanced.
    Is your 1/4" input jack truely balanced ... in this case it would need to be a TRS jack.  This is usually not the case.  The RJR specs aren't very informative, but I'd guess thay are not balanced.
    That said there is no technical problem either way you would like to run.
