99 Views 5 Replies Latest reply: Mar 4, 2013 8:05 AM by DickFoster RSS
stevefitz1 Just Startin' 5 posts since
Dec 19, 2010
Feb 22, 2013 7:25 AM
FBV longboard problem
I have just got an fbv longboard to use with my Vetta 1 which has been upgraded to 2. Works fine apart from the volume pedal switches off between sounds, which means I have to down the volume pedal to switch it on nearly every time i change the sound or it comes on at full volume. Not good when at a gig and you have to change quick. Also my Vetta has always made some strange buzzing noises when playing at high volumes between playing. Any ideas on how I could keep the FBV volume on would be great.
  • DickFoster Just Startin' 98 posts since
    Jan 26, 2012
    Feb 22, 2013 1:19 PM (in response to stevefitz1)
    Re: FBV longboard problem
    I'm thinking all you have to do is to turn the pedal on then save the patch with the pedal still on. You have to do this for each patch you want to use with the pedal/pedals on because they're both off/inactive by default.
    You can also reassign pedal function then save the patch with the reassignment active. When you punch up that patch again it should the way you saved it.
    The buzz could be coming from the guitar, a bad cable or many other sources. It would be a good idea to just switch off the amps with the amp on buttons between sets. Or if you're talking about between solos, use that volume pedal because, that's what it was really made for. Or maybe some caps in the power supply are starting to go south. Any florescent lights in the area?
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
