110 Views 5 Replies Latest reply: Feb 26, 2013 10:19 AM by Triryche RSS
micz2255 Just Startin' 2 posts since
Feb 16, 2013
Feb 23, 2013 1:48 AM
Line 6 studio pod processed and unprocessed recording signal
Hello everyone,
I would like to ask you how to change the sound processing in line 6 studio pod, I have the latest driver version 4.2.5.4, I go to menu driver line6 audio-midi device and next i switch to "inputs & recording" and here i have question. How to change for example: "instrument unprocessed" to "instrument processed" ?
Greetings, Michael
  • hulbert Iknowathingortwo 375 posts since
    May 12, 2011
       I think you have Pod Farm Standalone, do you? If you do, then open it and click on the 'mixer view' button. Then go to 'send 1-2' and 'send 3-4', and if you want your recording programme to have the option of recording processed as well as unprocessed sounds, then click in the bok above them and make one of these two 'dry input' and the other 'tone A' (might say tone b also and tone a-b, depending on the type of preset you are using in podfarm).
    If you choose dry input as send 1-2 and tone a send 3-4, then in your recording programme you would make a new track and select the input that you prefer. If you want the dry unprocessed sound, then select send 1 or 2 (or send 1-2 if you want a stereo track). If you want processed, select send 3 or 4 (or send 3-4 for stereo). If you want to record both at once, you can create two tracks and select one as i.e. send 1, and the other as send 3 (or whichever number) and you will then get one track recorded with the unprocessed sound and another with the processed sound.
    Hope this helps,
    God Bless,
    David
        May 12, 2011
           I have had a look at my one and it says the same as yours. If you change the settings in mixer view I think it should change it to the processed sound. I haven't got my guitar plugged in just yet but I know that I have recorded processed audio as well as un processed. I tried changing it in mixer view but it did not change the setting in the Line 6 Audio-Midi devices box. I will have a go with my guitar later and see if it changes it.
          May 12, 2011
          I have tried changing the settings in mixer view and then I closed podfarm standalone (I do not know if you have to). I set my recording programme to record a track and then turned standalone on and played and it recorded the processed sound. I did not have to change it in Line 6 Audio - Midi devices.
          (At first I forgot to turn pod farm back on and it only recorded the unprocessed sound , and then I realised that I had to have pod farm standalone on. It then worked.
          Try doing this and see if it works for you.
          God Bless,
          David
  • Triryche Expert Line 6 User 3,698 posts since
    Feb 20, 2007
    The Line6 Audio-MIDI control panel for a POD Studio or Toneport allows you to select the input source. This is to pass audio to your DAW with out using POD Farm, and it will always send unprocessed if you do not use POD Farm ToneDirect Monitoring (standalone). Also, without POD Farm launched, no audio from the POD Studio's inputs will be passed to the analog or headphone outs.  As soon as you launch POD Farm Standalone the recording options in the mixer view override the control panel settings.
