Feb 23, 2013 8:53 AM
Recharcheable batteries in Variax 700?
Like (0)
Hi there. I mostly use my 700 electric via VDI into my HD500 for gigging, but have the battery pack with fresh batteries in the case in the event of the HD500 failing - I could then use the jack out with a normal guitar cable. But I would also like to use the jack out for jams etc. when I don't have the HD500 with me - at the moment I usually take along another guitar.
Anyone tried recharcheable batteries - if so do they work? This could save some money on normal AAs....
Many thanks in advance for your answers.
there are different thoughts on them. used to be if you didnt let them bottom out then they would have shorter and shorter life as time went on. in the case of the variax i found that if the batteries werent at peak or near to it i would have problems if you test your regular batterys for charge when they dont run the variax you may find like i did that the battery has plenty of charge to be used elsewhere. in my case i used a 9 volt vs the aas. every time there was plenty left.
that being said the more modern ones are supposed to be better. but i havent tryed them.
theres only one way to find out.
Thanks for your reply - I've never tried the Variax with a 9v - how long do they tend to last??
really no longer than tha aas but i didnt have the battery holder so thats what i used.. no problem using them at all then when they didnt run the vax they were still good for a long time in my pedals.. i think once they were down about 20 percent that was it in the variax. but every time id check them and the needle on my battery checker was well into the green. so into a pedal or a tuner or what ever else needed a battery. so i atleast got my moneys worth out of the battery.
Thanks, that's good to know. I think I used to get about 6 hours out of the AAs (but haven't used batteries for years as I gig with the VDI cable) - is it about the same (6 hours) for the 9v in your experience?
es thats about what i got. otoh when i first got it and if i left the trs cable plugged into it. that would seriouslu drop. the key was when not playing unplug the guitar as the trs cable is the on off switch for the battery. when i transpanted the vax into another body i also made up a strap woth two attery pockets. inside the strap i put a set of wires going too a 9 volt connector end. at the bottom of the strap a wire with the same end went into the back battery area. the pockets were up front where i could easily get at them . were the battery to go on me. i could quickly change tothe other in a couple of seconds woithout putting the guitar down or having to fiddle with that back door on the guitar...
my own little inovation.
Thanks for your reply. I like your 2-battery innovation - sounds great. I guess with a transplant you can do your own thing and add stuff which works for you. There seemed to be plenty of transplants around with the original variaxes - I wonder if anyone has transplanted a JTV yet? I've tried a JTV-59 and a JTV-69 and wasn't that impressed with build quality - and the necks were strange IMO - nut width too narrow, frets too big for me. Neither of them were anywhere near the quality/playability of my 700 electric. But as time passes I'm getting more and more anxious about my 700 failing and not being able to mend it as Line 6 don't seem to be supporting them anymore....
thats how i felt about my 300. the neck was bearable but that over thick body was uncomfortable.
and clunky
i put min in a dan electro dc 59.
as to the new ones. well i think at some point theres going to be people transplanting just for the reasons you mentioned. but at that price i dont think youll see that soon.
probably years up the road when there on ebay for resale..
as to line 6 support. anything with electronics ends up that way for two reasons . some people dont garee though. one is it cost money to stock items that are outdated . one is wasted space and the other is inventory tax. the second is people move on it doesnt pay to stock these old items for a couple of chances someone may need them. example of this is old radios. my brother is into that he has a very hard time getting parts . so he goes to flea markets and sales and has to do his own stocking of spare parts.
if you really like your 700 then i would suggest the same to you. pickups can still be gotten from lr baggs but i think you need to buy a set. as far as the boards you will have to check places like craisg list ebay etc to try to find them. also keep a few backup copys of the software updated drivers or what ever might be needed on an external hard drive or one of those chips everyone is using these days incase line 6 decides to delete all that stuff..
unfortunately we live in a fast paced society where change is the order of the day and everything is throw away and not made to last. as to the necks on the new ones ..well id imagine there still using bolt on necks . if youdecide to get one most likely they are still using gibson and fender neck pocket dimensions and this would allow you to get what you want from either one of them or order a warmouth neck..
