Feb 26, 2013 1:41 PM
POD X3 Live Recording Problem
Like (0)
Back in September I wiped my computer and therefore had to re-install all the POD X3 Drivers etc. Since then, recording is now impossible. In every video I try to record at exactly 30 seconds I start getting a weird chopping sound and the recording will fall behind when synched up with an actual song.
So to sum it up better I guess:
- Open up webcam program to record
- Set POD X3 as mic
- After 30 seconds exactly a weird chopping sound comes in
- Recording will de-sync from that point on even though perfectly matched up before the 30 seconds.
I tried using other mics in the webcam program and there is no issue. It's only when I set the POD X3 as a microphone that I get the issue.
Help is greatly appreciated.
Thanks!
I havent got my X3l connected at the moment so cant absolutly check this but have you tried changing the buffer size in the Lin6 6 audio device panel - which should be found in Control Panel.
Good luck
