92 Views 2 Replies Latest reply: Feb 27, 2013 10:41 AM by colmwiggle RSS
colmwiggle Just Startin' 16 posts since
Mar 3, 2010
Feb 26, 2013 1:52 PM
M13 FX Loop quandry
So I'm using FX Send and Return to patch in some other pedals and things.
It all works fine.
Then I record a loop.
Now I'm interested in effecting the recorded loop using the pedals I have routed the signal through using FX Send and Return. I cannot. I presumed you could in the same way as you can kick the Pre/Post button and re-effect the loop using M13 FX. Please can you tell me how I might achieve this using the FX Send and Return ( or if indeed such a thing is possible)
P.S.
I do know that I can simply put the extra pedals either after the M13 in the signal path or just put them through my amps FX loop.
Chairs and Tanks
  • phil_m Expert Line 6 User 4,243 posts since
    Jan 25, 2007
    Feb 27, 2013 6:23 AM (in response to colmwiggle)
    Re: M13 FX Loop quandry
    The pre and post settings for the looper really don't have anything to do with the effects loop. If you put the looper in pre position, it means it comes first in the M13's signal chain, so in essense, when you record a loop, it will be recorded dry. What that means is that if you change the effects after recording your loop, than your loop will be affected. If you put the looper in post position, the loop comes at the end of the M13's signal chain, and the loop will be recorded with whatever effects you have active at the time. This is helpful if you want to record a rhythm track with one sound and then change to a different sound for a lead tone.
    So if you have effects in the M13's effects loop, and you move the looper to pre, you could record a dry loop, than turn the effects in the loop on or depending on what you want, and the recorded loop would change. If you have the looper set to post, if you have the effects in the effects loop on while you record your loop, the loop will be recorded with those effects.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
