277 Views 12 Replies Latest reply: Mar 2, 2013 5:54 AM by familyguy RSS
familyguy Just Startin' 7 posts since
Feb 27, 2013
Feb 28, 2013 5:45 PM
Who's used the Pod HD for jazz tones?
What's the secret to getting a good jazz tone?    I'm a new user with only two days experience using the Pod HD bean into a PC and headphones.   .
I found something using the flip-top amp model after a few hours but it's not quite right.   I searched the forum and customtone for jazz tones but they seem to be incompatible files so I'm looking for options.   Any suggestions appreciated.
Thanks.
  • Akeron Just Startin' 224 posts since
    Jul 23, 2011
  • bjnette Just Startin' 82 posts since
    Sep 2, 2012
    Feb 28, 2013 10:51 PM (in response to familyguy)
    Re: Who's used the Pod HD for jazz tones?
    I know what you mean, I have been stuggling with good jazz tones too.
    A few nights ago I played with the Fender Bassman standard and that bottom end  was getting too much.
    The mic choice helps on the cabinet and a couple of EQ instances to balance the tone you want, befor and after the Amp block.
    You might just try looping a few chords and fills with the looper in the pre mode  and then tweak the Amp pages especially mic choice and resonnace. Also a 60-90ms delay inserted in the block can be used to get that roomy tone.
    My advice is to take a few breaks saving  what you got before you break and then come back and continue saving to a new tone. This way tyou can then audition your patches once your ears are fresh.
    when you get something you like, save it as a patch and move on.
    It is a good idea to go for tone matching as you are doing and as you are only on the HD two days it takes a little to come to grips with it.
    Really go for your Amp tone first and then a couple of EQs to smooth your response.
    I like the 63 Spring Reverb but the ducking one might be the ticket.
    Good luck with your jazz tones, not that mine a that good but I am getting some half decent funk tones.
      • hurghanico Just Startin' 399 posts since
        Jan 28, 2007
        Mar 1, 2013 12:41 PM (in response to familyguy)
        the solution without amp model is good for a 100% clean jazz sound, but if you want just a hair of gritty sound (which personally I like) that comes out during the loudest passages, an amp model becomes necessary ..
        in case you decide to use an amp model, a very interesting way to find several timbres it's experimenting thoroughly with the available mic models ..
        as an example, one of them gives a very warm and full-bodied tone to many cabs to which it is applied, in my opinion is very good for many genres of music, from jazz to hard rock ..
        I'm talking about the Royer 121 Ribbon (121 Rbn) .. but to give the best of itself requires an extremely open amp eq (mid, treble, presence), otherwise it is dull ..
        Sep 2, 2012
        Mar 1, 2013 3:41 PM (in response to familyguy)
        Focus EQ has hi lo shelving and might be one your already using.
        The guitar you use is the key factor in your tone and perhaps why my jazz tone attempts
        haven't quite nailed it yet.
        I'll give the no amp in the block a try.
      Jan 28, 2007
      Mar 2, 2013 4:51 AM (in response to familyguy)
      familyguy ha scritto:
      ...the brittle highs that so many models have..
      ......The models don't approach that real fender sound, at least my fledging attempts aren't successful...
      maybe you missed one of my previous answers, but again I strongly suggest to try different mic models (or cabs) for every amp model as they influence really a lot the resulting timbre..
      as I said before just as an example the 121 Rib is a very warm sounding mic which cuts off a lot of the harsh part of the the sound you may hear with some of the other mics..
      anyway if the no-amp will be your definitive solution you may also consider to use the Requisite Y7 vintage Tube Mic Preamp model (Vintage Pre) to provide some nice tube warmth, it has the following controls: Gain, Output, Phase, Hi Pass Filter, Lo Pass Filter..
      (and also having this Preamp Model within the FX Blocks rather than in the Amp Blocks allows you the flexibility of positioning it anywhere in the signal chain)..
      you can find it under the Preamp+EQ Models section..
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
