67 Views 2 Replies Latest reply: Mar 3, 2013 8:21 AM by rv456 RSS
rv456 Just Startin' 6 posts since
Oct 27, 2010
Mar 2, 2013 9:01 AM
HD500 looper overdub problem
Hi, I recently got a PPOD HD500 and have a problem with the 'Overdub' feature of the looper.  When I try to overdub (after already recording the 1st loop) it will only record 1/2-3/4 of what I play.  I can tell when this will happen as it sometimes even seems to double what im playing, whilst I'm still recoding.  I press the overdub button as soon as I start playing so it's not due to me cutting the first partout manually.  Also sometimes, when I manage to get the overdub in, it will play back once, then stop for 4 bars or so, then play again.  Please could someone help as I am trying to practise looping the outro to 'On Impulse' by Animals as Leaders, as part of a solo guitar performance on Monday.  Incase your interested, the looper is set to 'Post' mode and '!/2 speed'.
  • bjnette Just Startin' 82 posts since
    Sep 2, 2012
    Mar 3, 2013 6:50 AM (in response to rv456)
    Re: HD500 looper overdub problem
    Could be at half speed playback you sitll only get the 25ses of record time on the overdub.
    If you are overdubbing with the same patch you can do so by hitting play and leaving looper on and what you then play will be layered overdubs untill you switch looper to off.
