83 Views 1 Reply Latest reply: Mar 8, 2013 7:27 AM by ArneLine6 RSS
mrose101 Just Startin' 8 posts since
Jul 10, 2010
Mar 8, 2013 5:32 AM
separate monitor eq
is there a way to have separate monitor eq from the main mix eq?
  • ArneLine6 Line 6 Support 172 posts since
    Mar 14, 2012
    Mar 8, 2013 7:27 AM (in response to mrose101)
    Re: separate monitor eq
    The EQ's for the outputs are sparate. The channel EQ is before the sends. If you want to have different channel EQ's on the monitor send you can use a Y- split cable and turn up one channel to the monitors and the other one to the main mix. If you want different output EQ's for the main mix and the monitors use the separate EQ's in the main and in the monitor outputs. Select the monitor or main output, press tweak and EQ.
Legend
  • Correct Answers - 5 points
  • Helpful Answers - 3 points
