CATALYST AMPLIFIERS
Original Amp Designs
The Catalyst® family includes three dual-channel combo amplifiers that perform like traditional guitar amps—while providing the increased versatility of modern amplifiers. From the 200-watt Catalyst 200, capable of holding its own on nearly any stage, to the 60-watt Catalyst 60, which is perfect for practice, recording, and performing in small venues—there’s a Catalyst amp for every player. Catalyst amplifiers offer six Original Amp Designs—ranging from pristine clean to modern high-gain—crafted using our renowned HX® sound design techniques to ensure exceptional tone and feel. These powerful and sturdily constructed combos are equally suited for stage or studio use, and feature an XLR line output and a 4-channel USB recording interface. Also included are Boost circuits customized for each amp type, a dedicated Reverb section with six reverb types, 18 additional effects, an effects loop, a Power Amp input for using Catalyst as a powered speaker, MIDI capabilities, and power attenuation options for playing at any volume. The free Catalyst Edit app for desktop and mobile devices provides deep editing capabilities. Add an optional LFS2 footswitch for even more flexibility, and an optional cover to protect your combo.
  • Clean
  • Boutique
  • Chime
  • Crunch
  • Dynamic
  • Hi Gain
Click play to hear samples.
Explore Features
  • Original Amp Designs
  • Traditional Controls & More
  • Pro Connectivity
  • Dedicated Boost
  • Dedicated Reverb
  • 18 Additional Effects
  • Effects Loop
  • Output Power
  • Power Amp In
  • USB
  • MIDI
  • Footswitch
Catalyst 200
The Catalyst 200 combo amplifier operates like a traditional guitar amp, while providing the increased versatility of a modern amp, and features six Original Amp Designs crafted using our renowned HX sound design techniques.
Catalyst 100
The Catalyst 100 combo amplifier operates like a traditional guitar amp, while providing the increased versatility of a modern amp, and features six Original Amp Designs crafted using our renowned HX sound design techniques.
Catalyst 60
The Catalyst 60 combo amplifier performs like a traditional guitar amp, while providing the increased versatility of a modern amp, and features six Original Amp Designs crafted using our renowned HX sound design techniques.
CLICK TO EXPLORE
CHANNEL SELECT
Press either the CH A or CH B button to select the channel to configure.
Press MANUAL to enter Manual mode and use the knobs like a traditional amp.
GUITAR INPUT
Plug your guitar in here.
AMP SELECTOR
Use this encoder knob to select from the Line 6 Original Amp Design Voicings.
BOOST SWITCH & KNOB
Press the switch to enable/disable the Boost feature. Use the knob to adjust the Boost level.
GAIN
Controls how much distortion you get in your tone.
BASS, MID, TREBLE
Allow you to adjust the overall EQ for each preset that you store. When in “MANUAL” mode, these knobs operate just like those on a traditional amp.
PRESENCE
Boosts specific upper midrange and treble frequencies to make your tone more pronounced and “present” in a mix.
CH VOL
Controls the preset's channel volume.
EFFECT SWITCH & KNOB
Press to enable the on-board digital effects. Press and hold this button for 2 seconds, then use the “TAP” button to switch between the effect types (Delay, Modulation, Pitch/Filter).
TAP/TUNER BUTTON
Tap in time with the music to set the tempo of delay and modulation effects. Press and hold to engage the Tuner.
REVERB SWITCH & KNOB
Press to enable the on-board digital reverb.
MASTER VOLUME
Controls the overall volume of the amplifier as well as headphone output.
  • CHANNEL SELECT
  • GUITAR INPUT
  • AMP SELECTOR
  • BOOST SWITCH & KNOB
  • GAIN
  • BASS, MID, TREBLE
  • PRESENCE
  • CH VOL
  • EFFECT SWITCH & KNOB
  • TAP/TUNER BUTTON
  • REVERB SWITCH & KNOB
  • MASTER VOLUME
POWER SWITCH
Turns the amplifier on/off.
AC IN
The included power cable connects here.
OUTPUT POWER
Controls the overall power amp output. There are four options: MUTE (for recording/headphone use), ½W (0.5 Watts), 50% (half power), and 100% (full power).
USB-B PORT
Connect a device to edit tones, update, playback, and record audio. This class-compliant USB connection offers 4-channel audio at 24-bit depth and 44.1 kHz or 48 kHz sample rates.
MIDI IN
Connect an external MIDI controller device to the 5-pin MIDI DIN connector here to control preset changes, controller assignments, and more (available on CATALYST 100/200).
FOOTSWITCH
Connect the optional Line 6 LFS2 2-button footswitch here to control A/B channel switching and Effect on/off.
AUX IN
An auxiliary audio input for running external audio sources directly (unprocessed) into the amplifier’s speakers.
PHONES
Connect a pair of headphones here. The top panel’s MASTER VOLUME controls the level to your headphones.
FX LOOP
Connect external effects using standard 1/4" instrument cables.
MODE SWITCH
Controls the state of the FX Loop RETURN; When switched to the left, the FX Loop is engaged (as described above). When switched to the right, Power Amp In is engaged, sending the return signal directly to the power amp. This feature is great for use with external effects processors or pedals.
GND-LIFT
Ground lift switch for XLR DIRECT OUTPUT(S).
DIRECT OUT
Connect an XLR cable to route audio to a PA, mixer, or audio interface. The output level for the DIRECT OUT is fixed at line level (not affected by the MASTER VOLUME knob).
  • POWER SWITCH
  • AC IN
  • OUTPUT POWER
  • USB-B PORT
  • MIDI IN
  • FOOTSWITCH
  • AUX IN
  • PHONES
  • FX LOOP
  • MODE SWITCH
  • GND-LIFT
  • DIRECT OUT
SIGN UP TO LEARN MORE
