Q: If the AMPLIFi product works as a sound card through USB, what would be the way for connecting a pair of studio monitors to do the mixing with? How does the IO on AMPLIFi with USB recording enabled work? Is it a 2-in/2-out? If so, does AMPLIFi act as the 2-out monitor?
A: The AMPLIFi amp becomes your sound card when using USB to record, so while you're recording using an amp, it's easiest to monitor computer playback through the amp – it really does sound great. You could always use the headphone outs to get a direct signal into studio monitors via a mixing board or other solution, but the intent is to use the amp for monitoring – at lease while you are recording. Once you are done recording, you can can mix using whatever setup you like. For AMPLIFi TT or AMPLIFi FX100, you would just connect monitors to the main outs on the units.
Q: What bit depth and sampling rate can you use when recording with the AMPLIFi series?
A: The AMPLIFi series can record in 24bit with sampling rates from 44.1k up to 96k on Windows and in 24bit with sampling rates of only 48k on MAC OSX. When using the AMPLIFi series for operating system audio you can adjust these within Control Panel on Windows and System Preferences on MAC OSX. When using the AMPLIFi series within a DAW, you can adjust these within the Audio Preferences/Options of the DAW.
Q: What operating systems are the AMPLIFi series USB audio drivers compatible with?
A: Our Windows ASIO USB audio driver is compatible with Windows 7 and Windows 8 and can be downloaded from our software HERE. The AMPLIFi series is CoreAudio compatible on MAC OSX 10.7 and above, therefore does not require the installation of any additional drivers.
