justinvirgil Posted October 24, 2014 Share Posted October 24, 2014 NOTE: never have i tried to plug it into a computer.I am also a bit challenged when it comes to software and stuff. i leave it to my friends to fix my pc tbh. So while i was practicing the other day, i noticed that some of my Settings weren't sounding the same...then when i tried to reboot my gear, i noticed that it now shows a message that i have never encountered before standard model set loadedis there any way that i can recover it? since those modpacks originally came with the unit right? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted October 24, 2014 Share Posted October 24, 2014 depends on the model packs... but i think only the power pack and fx junkie MAY have come with the XT live... if you bought it used and it had other model packs installed... you wont be able to recover those. Quote Link to comment Share on other sites More sharing options...
justinvirgil Posted October 25, 2014 Author Share Posted October 25, 2014 yes, power pack and fx junkie came with the XT Live. is there any way i can recover it? to make it work again? Quote Link to comment Share on other sites More sharing options...
TheRealZap Posted October 25, 2014 Share Posted October 25, 2014 much depends on why it stopped working.... if you plug it into a pc and launch monkey and monkey shows ESN 000000 then your security chip went bad and there is no way to recover... other than replacing it (cheaper to buy another used one) however if monkey shows an ESN with actual numbers and not just 0's you can probably reflash it and get it to work. Quote Link to comment Share on other sites More sharing options...
crice53 Posted November 6, 2014 Share Posted November 6, 2014 I had to download the new Line6 License Manager and re register the gear to the computer, and they all reappeared...... simples. Quote Link to comment Share on other sites More sharing options...
justinvirgil Posted December 3, 2014 Author Share Posted December 3, 2014 hi there and good day.i've tried the monkey thingy and the license manager and it just won't reappear. can you kindly give me a step by step on how to do it properly? Thank you so much.and no, it doesn't show 00000000 Quote Link to comment Share on other sites More sharing options...
BillBee Posted December 3, 2014 Share Posted December 3, 2014 So when you turn the XTL on the packs don't flash on the start up screen? Even after you went through the license manager and made sure the XTL was selected and authorized (this will show what is what as far as whats authorized in the screen)? If no to the above, you should reflash the unit and start fresh (back up your patches first): Q: How do I reflash my PODxt unit?1. Download and install the latest version of Line 6 Monkey from the following link:www.line6.com/software2. Run the Line 6 Monkey program and log into Line 6 Monkey using your Line 6 user name and password. If this is the first time you have run Line 6 Monkey, you will not have driver software installed. Highlight the "Driver" item in the Updates window, and click the Update button on the right. Monkey will lead you through the installation process, which requires you to quit Monkey and possibly restart your machine. See the following link for more information on driver installation.3: Make sure your PODxt unit is powered on and connected to your computer via a USB 2.0 connection. Monkey should automatically recognize your PODxt and complete the startup sequence. See the following link for USB troubleshooting tips if Line 6 Monkey does not recognize your PODxt unit.4. On the Updates tab, look to see if your Flash Memory is up to date. If it is out of date, you will see a yellow "yield" sign next to flash memory.If you need to update (or just want to reset the unit back to factory state for troubleshooting) select "Flash Memory" (it will highlight in blue) and click the "Update Selection/Reinstall Latest" button to the right. Monkey will lead you through the process.Monkey will give you an option to continue:Monkey will then ask if you want to keep your presets. If you do not want to keep the presets (or have already backed up your presets), select "no".Monkey will now update your unit after you select "yes". Be sure to close all other applications and heed the warnings.You will see the progress bar writing the flash to your unitRestart your POD XT unit by powering the unit off, then back on.When the update is complete you will receive a message stating it installed sucessfully. That should do it. -B Quote Link to comment Share on other sites More sharing options...
justinvirgil Posted April 13, 2015 Author Share Posted April 13, 2015 So when you turn the XTL on the packs don't flash on the start up screen? Even after you went through the license manager and made sure the XTL was selected and authorized (this will show what is what as far as whats authorized in the screen)? If no to the above, you should reflash the unit and start fresh (back up your patches first): Q: How do I reflash my PODxt unit? 1. Download and install the latest version of Line 6 Monkey from the following link: www.line6.com/software 2. Run the Line 6 Monkey program and log into Line 6 Monkey using your Line 6 user name and password. If this is the first time you have run Line 6 Monkey, you will not have driver software installed. Highlight the "Driver" item in the Updates window, and click the Update button on the right. Monkey will lead you through the installation process, which requires you to quit Monkey and possibly restart your machine. See the following link for more information on driver installation. 3: Make sure your PODxt unit is powered on and connected to your computer via a USB 2.0 connection. Monkey should automatically recognize your PODxt and complete the startup sequence. See the following link for USB troubleshooting tips if Line 6 Monkey does not recognize your PODxt unit. 4. On the Updates tab, look to see if your Flash Memory is up to date. If it is out of date, you will see a yellow "yield" sign next to flash memory. If you need to update (or just want to reset the unit back to factory state for troubleshooting) select "Flash Memory" (it will highlight in blue) and click the "Update Selection/Reinstall Latest" button to the right. Monkey will lead you through the process. Monkey will give you an option to continue: Monkey will then ask if you want to keep your presets. If you do not want to keep the presets (or have already backed up your presets), select "no". Monkey will now update your unit after you select "yes". Be sure to close all other applications and heed the warnings. You will see the progress bar writing the flash to your unit Restart your POD XT unit by powering the unit off, then back on. When the update is complete you will receive a message stating it installed sucessfully. That should do it. -B it didn't im at a loss here..i can't replicate my tones now if i factory reset my pod. since the effect tweak knob isn't working properly anymore Quote Link to comment Share on other sites More sharing options...
justinvirgil Posted April 13, 2015 Author Share Posted April 13, 2015 these are factory add-ons btw. Quote Link to comment Share on other sites More sharing options...
BillBee Posted April 13, 2015 Share Posted April 13, 2015 The XTL model packs do not come free except for the FX Junkie and maybe the Power Pack IIRC. The others like the Metal Pack you have to purchase. The Line 6 License Manager has to be run in order to authorize any add-ons. If the tweak knob is bad you should look into submitting a support ticket and have it repaired by an authorized service center. -B Quote Link to comment Share on other sites More sharing options...
