jtv 69+hd500 4 cable method
Hello everyone,i need a little advice. I want to connect, my jtv 69 and pod hd 500 to a boogie express combo, using 4 cable method, now i know how to connect  that ok but i want the acoustic sounds from the variax to go direct to the PA (foh).i want to use the cat5 cable from guitar to hd500 to power the guitar, could i use a standard cable from the jtv 69 to the pa (2 cables from guitar) or is there a better way?. thanks.
  • 4 weeks later...
You should be able to do all the routing within the HD500 on a patch by patch basis.  For example you have your 4CM which i presume would be mono anyways.... then send your balanced left or right (whichever is not being used for mesa) signal from the hd500 straight to the desk.
That way, by simply switching a patch you can go from electric through your mesa to acoustic straight to FOH.....(via your pod of course)
it also means you can send a 'effected' signal from pod to FOH, which for the variax acoustic models IMHO is necessary.
hope that helps!!
