gtrman100 Posted October 29, 2014 Share Posted October 29, 2014 I'd been having a few volume and tone issues with my DT25, the volume seems to had dropped a bit, and the tone had sounded a bit weak, and not as punchy, so I figured t was time to retube,, I've had JJ's before and they were a good sounding, not excessively expensive tube, so I bought a set from Eurotubes. They were delivered quickly and I highly recommend them. The verdict- huge improvement in tone! The volume is back- headroom has increased markedly.The tone is tight and focused, and the low end isn't flabbly at all. I can crank a high gain tone to pretty high volume and not get mushy. The balanced 12ax7 in the phase inverter section might be responsible for the improved headroom. If you're looking for replacements, you might try these out. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted October 29, 2014 Share Posted October 29, 2014 That's what I switched to after the original tubes went out in less than 90 days. I'm totally happy with the results. Quote Link to comment Share on other sites More sharing options...
GazzaBloom Posted October 31, 2014 Share Posted October 31, 2014 I have a DT25 and want to be ready to change the tubes when the time comes. Thanks for the recommendation. Did you rebias the amp at all when you fitted the new tubes? (I would need a repair technician to help me with that) Gazza Quote Link to comment Share on other sites More sharing options...
ice9mike Posted November 1, 2014 Share Posted November 1, 2014 I would like to know the lifetime most are seeing with the JJ tubes in the DT25. Mine lasted about 3 months before blowing out and taking the fuse with them. I did really like to tone of the amp with the JJ's, but have refrained from using them after they blew. Quote Link to comment Share on other sites More sharing options...
gtrman100 Posted November 2, 2014 Author Share Posted November 2, 2014 I have a DT25 and want to be ready to change the tubes when the time comes. Thanks for the recommendation. Did you rebias the amp at all when you fitted the new tubes? (I would need a repair technician to help me with that) Gazza I always rebias power tubes when changing. It can make a big difference on how the amp sounds and tube life. Quote Link to comment Share on other sites More sharing options...
gtrman100 Posted November 2, 2014 Author Share Posted November 2, 2014 I would like to know the lifetime most are seeing with the JJ tubes in the DT25. Mine lasted about 3 months before blowing out and taking the fuse with them. I did really like to tone of the amp with the JJ's, but have refrained from using them after they blew. I've had JJ's in other amps before, and never had a problem with reliability. Any brand or quality of tubes can fail, so I would buy them from a reputable dealer which usually comes with a warranty. Quote Link to comment Share on other sites More sharing options...
DarrellM5 Posted November 3, 2014 Share Posted November 3, 2014 I did re-bias when I put the new tubes in. Piece of cake after watching a few youtube videos. So far they've lasted 5 months and still going. Quote Link to comment Share on other sites More sharing options...
stumblinman Posted November 4, 2014 Share Posted November 4, 2014 Mine made it about four months and took the fuse with them too. I would like to know the lifetime most are seeing with the JJ tubes in the DT25. Mine lasted about 3 months before blowing out and taking the fuse with them. I did really like to tone of the amp with the JJ's, but have refrained from using them after they blew. Quote Link to comment Share on other sites More sharing options...
