bmancini42 Posted June 18, 2013 Share Posted June 18, 2013 You know, what I'd really like to do, rather than have 4 buttons access patches, 2 buttons access bank, and 4 buttons do various switches, is have more direct patch access. Is this possible with the HD500? Quote Link to comment Share on other sites More sharing options...
pfsmith0 Posted June 18, 2013 Share Posted June 18, 2013 It is my understanding you can use a MIDI foot controller to send MIDI commands to the HD500 to do the bank switching, Then you would have 8 buttons for direct patch access. Quote Link to comment Share on other sites More sharing options...
bmancini42 Posted June 18, 2013 Author Share Posted June 18, 2013 Sure, I guess that would work, although I wouldn't want to carry around two foot controllers. What about the HD500 itself? I understand you can program it to send MIDI CCs and etc, can you also have it send MIDI PCs to itself, etc. or does that only work with external devices? Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted June 19, 2013 Share Posted June 19, 2013 I haven't tried it 'cause I am at work but you could connect MIDI Out/Through to MIDI In. - Make sure that it is in Out mode in global settings to avoid a MIDI feedback loop. Then program the footswitches to do Program Change. The foot switch press will sent the Program Change, which will be received and then change the HD500 Patch, at this point the HD500 will automatically send the same Program Change message because it does this automatically and then receive it and if you are lucky ignore it because it is the current Patch. If you are unlucky it will change Patch again, and then send the Patch Change, and change Patch and then send Patch Change.... basically go into a Patch change loop. Pull the MIDI cable to break it. The other really tedious part of this is that the MIDI assignments are specific to a Patch, so you would have to set them up the same in all of the Patches. 1 Quote Link to comment Share on other sites More sharing options...
bmancini42 Posted June 19, 2013 Author Share Posted June 19, 2013 That sounds like it might work. I haven't got an HD500 yet, I am probably getting one this weekend, I will have to try that out when I do. Quote Link to comment Share on other sites More sharing options...
bmancini42 Posted June 25, 2013 Author Share Posted June 25, 2013 Worked like a champ, thanks. Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted June 26, 2013 Share Posted June 26, 2013 Great - I didn't get a chance to try it myself as I am too busy learning some keyboard parts. Quote Link to comment Share on other sites More sharing options...
Xergoth Posted November 12, 2013 Share Posted November 12, 2013 please elaborate. when I do this, the looper function activates too when the looper button is pressed (I don't want that) Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted November 12, 2013 Share Posted November 12, 2013 I guess that the Looper mode is a problem as it will also do a mode change (again haven't tried it as I am at the day job), but it should work for Bank Up and Down, the 8 FS and Tap, which is 11 switches. Not everything on the HD units is quite as logical as it could be. Quote Link to comment Share on other sites More sharing options...
