JimNiven Posted November 20, 2014 Share Posted November 20, 2014 Using the guitar jack input on Sonic Port VX into Mac in Garage Band, I get some level of both input and recorded guitar volume but pretty low, even when the guitar is at max. vol. It is recording ok but at a low level. Tried different guitars. Same problem. Any ideas how to fix this please ?? Quote Link to comment Share on other sites More sharing options...
braguesa Posted November 21, 2014 Share Posted November 21, 2014 I have the original and the new sonic port and yes, both have lower input levels than other interfaces I have. The mics of this new version sucks, too much noise on them. I thought it was a problem of my device but a friend has the same problems, it's a bad piece of gear, forget about quality here. I would like to ear a mic demo of someone out of line6, has I believe they use some kind of audio processing on their videos. It's impossible they can reach son low background noise on the recordings. 1 Quote Link to comment Share on other sites More sharing options...
ArneLine6 Posted November 22, 2014 Share Posted November 22, 2014 Jim, are you using the built in guitar amp simulation in GarageBand? The signal coming out of the amp simulation will have a higher level. The guitar input uses two converters. This is how we get 120dB of dynamic range meaning the noise floor is very low. Braguesa, we have explained this a few times, the recording in the video was recorded with Sonic Port VX and then mixed using the usual EQ, compression and reverb but nothing else. Quote Link to comment Share on other sites More sharing options...
JimNiven Posted November 25, 2014 Author Share Posted November 25, 2014 Cheers ArneLine6 but ............... I have now tried both the GarageBand inbuilt guitar sim. as you suggest and the Mobile POD app. Sorry, but still no success. Neither gives enough level and there seems no way to adjust the input recording level. You get what you get.... low levels and fixed and this is with the guitar vol. set to max. For when I plug in the Sonic Port VX the GarageBand record level slider icon disappears in the input settings options . Remove the Sonic Port and the GarageBand input level slider reappears. Still struggling with lack of guitar input !! NB the mic. is ok. I adjust the input level for this using the vol. control knob on the Sonic Port unit. Still need help please. Quote Link to comment Share on other sites More sharing options...
