itai1984 Posted January 11, 2015 Share Posted January 11, 2015 Hi I just bought used guitar that appeared in good condition. the problem is that when i press the guitar model selector nothing happens. the guitar is being recognized by the workbench HD andi'm able to download or upload presets or play the magnetic pickups. the battery is charged. any idea what am i missing here? thanks Quote Link to comment Share on other sites More sharing options...
line-6-user Posted January 27, 2015 Share Posted January 27, 2015 Does the model knob light up when you push it? If not, gently pull it off the guitar, fold the tiniest of paper 3-4 times and insert it inside the knob, then refit back on the guitar. several JTV guitars that I tried all had the same problem... bad knob manufacturing or too short switch stem. Mine has been working flawlessly, since the mod. Hope this helps you. 1 Quote Link to comment Share on other sites More sharing options...
musical1212 Posted June 22, 2015 Share Posted June 22, 2015 Does the model knob light up when you push it? If not, gently pull it off the guitar, fold the tiniest of paper 3-4 times and insert it inside the knob, then refit back on the guitar. several JTV guitars that I tried all had the same problem... bad knob manufacturing or too short switch stem. Mine has been working flawlessly, since the mod. Hope this helps you. I hate to admit that it helped me. I've been fighting that switch for months. When I took the control off, it worked every time. When I stuffed paper down the hole, it works every time. Good for you, bad for Line6 QC. 1 Quote Link to comment Share on other sites More sharing options...
clay-man Posted June 24, 2015 Share Posted June 24, 2015 I don't understand how Line 6 doesn't resolve these issues, unless it's an older JTV you picked up. Between this, the model knob cap falling off, and checking if piezos are working properly, it should be a simple QC procedure. Quote Link to comment Share on other sites More sharing options...
