tylerbutton Posted January 14, 2015 Share Posted January 14, 2015 I've seen a post regarding pod noise but that poster only had noise after selecting an amp. Mine is making a terrible amount of noise with nothing selected. I'm running through a power conditioner so it shouldn't be electrical and I have used several cables to eliminate that variable. Any ideas? Quote Link to comment Share on other sites More sharing options...
silverhead Posted January 14, 2015 Share Posted January 14, 2015 This may be an Inputs problem. For instance, if your preset has Mic selected as an Input there can be some background noise even if there is no mic physically connected. Check all input settings and connections. Also, is this symptom present with all presets or just some? Check to see if your Input settings are Global or Preset. Quote Link to comment Share on other sites More sharing options...
tylerbutton Posted January 15, 2015 Author Share Posted January 15, 2015 All the presets are even worse depending on the loaded effects/amps. I first discovered the noise in the new user settings section with entirely blank settings. Quote Link to comment Share on other sites More sharing options...
