lowyaw Posted January 20, 2015 Share Posted January 20, 2015 Been recently trying out HD500 in the place of my old trusty TC Gmajor, in the loop of the Triaxis preamp. I guess I need some specific tech info (sorry if it could show up in the search - i quickly glanced through couple of pages, there was nothing of interest to me): I run amp loop send > POD loop return "L/mono" > POD 1/4 unbalanced outs > amp's loop return. There is a switch on the POD that goes from "stomp level" (louder) to "line unit" level (quieter). As I have no idea how loud the loop send on the Triaxis is, in order not run into clipping in the POD, should I use line level? Does it attenuate the loop input level specifically? Is there any indication, how much input signal can POD tolerate before clipping? Is it a good idea to run the amp's send into POD's "loop return", as opposed to running into "guitar in"? POD should be in the studio/direct mode, as it seems to be the "flattest" mode and I suppose it colours the tone the least - is it correct? Thank you. Quote Link to comment Share on other sites More sharing options...
radatats Posted January 20, 2015 Share Posted January 20, 2015 forget the POD FX loop for what you are doing. Just go into the Guitar In and use the 1/4 out and you will have no issues. The switch you are asking about controls POD FX Send levels anyways. 1 Quote Link to comment Share on other sites More sharing options...
lowyaw Posted January 20, 2015 Author Share Posted January 20, 2015 forget the POD FX loop for what you are doing. Just go into the Guitar In and use the 1/4 out and you will have no issues. The switch you are asking about controls POD FX Send levels anyways. i thought guitar in was instrument level, and loop return - line level, which seems to be more appropriate in my case? am I applying wrong logic here? Quote Link to comment Share on other sites More sharing options...
radatats Posted January 20, 2015 Share Posted January 20, 2015 no your logic is fine but no need. If the signal is too hot into the POD use the PAD switch, I think you will be good to go. In any case you won't hurt it; see what sounds best to you. Quote Link to comment Share on other sites More sharing options...
