mvanvlack Posted April 25, 2013 Share Posted April 25, 2013 I have recently bought a POD hd500 and I love basically everything about it. However the on board expression pedal does not switch between states easily. I will often find myself tapping the foot switch forward several times before I can get a Wah to come on or go off. To the point where I am double checking the set up to make sure I included a Wah in the signal chain. If I was playing on stage this would realy throw me off. I know how to calibrate the pedal I have seen that here on the forums, however I am not sure that is the issue as I only see calibration addressing sweep range, which is fine on my deck. Is this a calibration issue or a physical defect? Or just user error (there is that possibility I may not know exactly what I am doing, aka not depressing the pedal properly. I don’t want to stomp on the thing)? Again I love the product, thank you for your assistance. -Mark. Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted April 25, 2013 Share Posted April 25, 2013 when the pod is new, the button to activate the wah is a bit hard .. for the time being do not use only the foot muscles but use also your weight, a bit like you're going up (gently) on the step of a staircase .. but do not jump on it! plus one Quote Link to comment Share on other sites More sharing options...
mvanvlack Posted April 26, 2013 Author Share Posted April 26, 2013 Thank you, I'm glad that's all there is to it.I sort of had a feeling that it was just me not using enough weight. Thanks again for the quick replies. Quote Link to comment Share on other sites More sharing options...
GTLazer Posted April 26, 2013 Share Posted April 26, 2013 Remember there's the red/green LEDs to let you know when it changes as well! Quote Link to comment Share on other sites More sharing options...
GTLazer Posted April 26, 2013 Share Posted April 26, 2013 plus one There's a button for that. :) Quote Link to comment Share on other sites More sharing options...
norrisd007 Posted April 26, 2013 Share Posted April 26, 2013 There is a way to make it easier to actuate. However, it probably will void the warranty. One is remove the pedal and remove the rubber bumper near the front. Two is remove the rubber bumper and from the back side drill out some of the material. Put the drilled-out bumper back in. The sticky tape they use should still adhere well. Note that without a bumper the metal switch inside will make a loud noise. Louder than before. If you hook up in studio direct mode then no problem. But if you are on microphones watch out. It's loud and more of a metallic thump than a click. One other way to get rid of this very annoying issue is to go inside and change the switch. Again, don't do any of this if you value your warranty. Quote Link to comment Share on other sites More sharing options...
toneman2121 Posted April 26, 2013 Share Posted April 26, 2013 There's a button for that. :) i took your advice and clicked on the button. there is a limit to the amount of "ups" you can initiate 1 Quote Link to comment Share on other sites More sharing options...
pod999 Posted September 17, 2013 Share Posted September 17, 2013 you might also try this method instead of removing that rubber bumper totally... http://line6.com/support/topic/2686-pod-hd500-expression-pedal-adjustment/ G W Quote Link to comment Share on other sites More sharing options...
