scias23 Posted January 27, 2015 Share Posted January 27, 2015 I want to simulate the exp2 like having a treble bleed on the guitar. I have no effect slot left for a volume pedal and my signal chain always starts with a screamer with drive at 0%, eq and tone almost neutral, and output at 100%. Does the output parameter change the overall tone of the tube screamer effect? I don't have my POD at the moment but I'm planning to assign the output param to exp2. Quote Link to comment Share on other sites More sharing options...
innovine Posted January 29, 2015 Share Posted January 29, 2015 I don't know much about either the tubescreamer or the exp2, but since no one else is answering... maybe the output changes the tone of the pedal, probably not, but what it certainly will change is the signal level going into following devices. So the higher you set the output level, the more you'll cause the next device in the chain to overdrive or distort. Quote Link to comment Share on other sites More sharing options...
scias23 Posted January 29, 2015 Author Share Posted January 29, 2015 I don't know much about either the tubescreamer or the exp2, but since no one else is answering... maybe the output changes the tone of the pedal, probably not, but what it certainly will change is the signal level going into following devices. So the higher you set the output level, the more you'll cause the next device in the chain to overdrive or distort. Well I think I just have to try it myself then. haha Quote Link to comment Share on other sites More sharing options...
jandrio Posted January 29, 2015 Share Posted January 29, 2015 trial & error is one of the best testing approaches ever... Quote Link to comment Share on other sites More sharing options...
