POD's variax tone lock resets when switching pickups
xavierb
I want to use my variax tone knob to control various settings from the HD500x, unfortunately the "tone lock" (which is supposed to keep the tone set to a fixed level at all times) "resets" when switching pickups on the variax:
  1. in HD500x edit, set the "Local control" to "tone lock"
  2. Set the tone knob to control (for example) the chorus mix
  3. Lower tone knob to 0% on the variax -> no change in tone, but chorus mix drops, as expected... so far so good :)
  4. Now... Change the pickup (using the selector) on the variax... sounds as if the "real" tone control has been rolled down to 0!
I expect the guitar's tone (in "tone lock" mode) to remain the same regardless of what I do to the tone knob.
BTW, the same problem happens in "Vol + Tone lock" mode.
My setup:
  • POD HD 500X Flash Memory v1.32
  • Variax JTV-89F firmware v2.10
Would be great if this was fixed in the upcoming v2.6 :)
  • 4 months later...
Yep 2.62 still does it... I know I can change the patch to change the pickup, but that's not what I want to do (I switch pickups quite a bit while playing) and it's a also big "waste" of patches IMO.
Let's hope someone from Line 6 sees this and gets it fixed, and that Helix doesn't have the same problem.
