mkuhn Posted January 29, 2015 Share Posted January 29, 2015 Hi, I have a H&K Grandmeister amp and am wondering how I can best record the DI output signal from the built-in redbox on my PC. I was hoping the UX with its inputs would work for that but I tested Mic and Line inputs without success. Any advice would be great. Michael Quote Link to comment Share on other sites More sharing options...
fflbrgst Posted January 29, 2015 Share Posted January 29, 2015 You should be able to go straight from the 1/4" output of the amp to the line input of the UX2. What do you mean by 'without success'? Quote Link to comment Share on other sites More sharing options...
mkuhn Posted January 30, 2015 Author Share Posted January 30, 2015 I tried using the redbox/DI output the GM provides. What I tried: - DI output AMP via XLR to MIC input. Failed. Tons of humming. No signal - DI output AMP via XLR/1/4" to Line input. Failed. Same noise and no signal - Line output AMP (1/4") to Line input. Failed. Same noise, etc - Speaker output AMP to Line input. Failed. So, I am clueless. I tried all of the available output channels but the result is always the same - humming and no signal. Quote Link to comment Share on other sites More sharing options...
mkuhn Posted February 4, 2015 Author Share Posted February 4, 2015 I figured it out. The issue was due to my USB connection to my PC. I used several USB extensions and one of it produced the problem. Replaced it. Problem solved. Hughes & Kettner pointed me in the direction of faulty cables. Line 6 support was very supportive :) but believed the devices line in was faulty. Life is good again. Quote Link to comment Share on other sites More sharing options...
