Global Hi Cut in v2.6
BlueViolince
I'm guessing that the new global EQ (without throwing any more drama into all this) will fix the whole cab vs, DI brightness issue. What I should be able to do, once it's updated, is get my patches sounding good through my (insert frfr of choice here), and then switch to either cans or PA and roll down the hi cut until the extra brightness is gone, correct? If I bring it down until just before the frfr cab starts to lose top end, then it should be a closer match, if it works right.  I always have to end up making lots of eq adjustment when I playing direct with IEMs, and maybe that will be solved soon.
Well, the biggest issue for me has always been rolling off the high end.  In fact, my 2nd outboard EQ pedal pretty much stays in a hi roll-off state.  Anything else can be ignored with the knowledge that it's good in the house, based on past experience.  It's the difference between an overly dark sound and ice pick highs.
