wilson69978 Posted February 17, 2015 Share Posted February 17, 2015 Hello friends. I have several questions if anyone can answer one or more I would be thankful. I am thinking seriously of buying a variax guitar and I am having trouble finding some info. I see many people are having software issues, so I need some answers before I take the leap. 1. I want to load the new L6 monkey version onto my mac book pro running OS X version 10.6.8. When I check the link on the software install page there is an error on the line 6 web page. I am hesitant to install not knowing system requirements; especially since monkey has worked fine with my gear so far. 2. Does the modelling work thru a regular amp, not a D25 or D50s etc. ie. Just a 1/4 inch cable? I thought I saw a guy on you tube just just the guitar cable. 3. will it work without the pod hd 500. 4. I have a pod hd 400 is there any functionality with this and the variax thru the line 6 link port. I would like to use if (if I could) with my present set up,which is modest. A pod Hd 400, A fender superchamp x2 head, with a home made cabinet housing a 12 inch Celestion G12 vintage 30 speaker. The amp is a hybrid tube amp. It has amp modelling, A 12ax7 and 2 power amp tubes. 18 watts I am a very avid player but not a pro. Also Heavy amps are out after back surgury. Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted February 17, 2015 Author Share Posted February 17, 2015 I forgot to mention I have a G30 wireless transmitter, would that work on a Variax? Thank you all. Quote Link to comment Share on other sites More sharing options...
Tboneous Posted February 17, 2015 Share Posted February 17, 2015 Question 1: Can't help on that one Question 2: Yes Question 3: If by "it" you mean a Variax then Yes Question 4: L6 Link is for hooking up the pod to a DT or L series amp &/or speaker Question 5: Yes, if you use a 1/4". If you plan to use the VDI, then No. 1 Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted February 17, 2015 Author Share Posted February 17, 2015 Thanks for your help Tbpneous. I really appreciate you taking time to answer my questions. Looks like it will work fine for me without the fancy amp and pod hd500. I still need to sort out the software issue as the workbench software seems very nice indeed! Quote Link to comment Share on other sites More sharing options...
Tboneous Posted February 18, 2015 Share Posted February 18, 2015 Thanks for your help Tbpneous. I really appreciate you taking time to answer my questions. Looks like it will work fine for me without the fancy amp and pod hd500. I still need to sort out the software issue as the workbench software seems very nice indeed! No worries! I had my JTV for a while before I took the plunge into the whole Dream Rig. It's well worth it! Your JTV takes on a new life as apart of the HD and DT. Take care T Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted February 18, 2015 Author Share Posted February 18, 2015 Thanks Again Tboneous. I got the software issue settled too. The latest version of Monkey will run on A mac with Os X version 10.6.8 installed. (in case anyone else was wondering) Quote Link to comment Share on other sites More sharing options...
