Sign in to follow this
symplerhyme
2 X 12 cabinet for Spider IV HD150
Can someone tell me if the Blackstar HTV212 HT Venue Series 212 Guitar Amplifier Cabinet will work with my Spider IV HD150?
Specs are as follows:
Rear-mounted jacks allow the cabinet to be used in mono (160W RMS; 4 Ohms or 16 Ohms) or stereo (80W/Channel; 8 Ohms per). Inside, two 12-Inch Celestion 80 Watt loudspeakers give this cabinet its voice. The HTV-212 is uses a 2 x 12 design.
Will it work? Yes. It's a speaker cabinet and a head. Sound will come out. Use both outputs into the stereo ins on the cab. What no one will be able to do is promise beyond a shadow of a doubt that the160W rating is sufficient to avoid blowing a speaker. On paper, it should be, especially if you're not running full-tilt all the time. However, there are no gaurantees. Conventional wisdom says use a cab rated for 1.5-2x  the amp wattage, then you don't have to think about it. 150 vs 160 watts is a much closer ratio than that. You could use it for years without a problem, or you could blow it up in five minutes...nobody will be able to tell you definitively one way or the other. Personally, I don't think it's likely that you'll fry anything. But unlikely doesn't mean impossible. If it were me, I'd be looking for a different cabinet.
The ohms are fine so technically yes, the watts will depend on how hard you push it I guess.
I just added a 300 watt 4x12 to my 120 watt head, thinking that even cranked up my cab should handle the heads output without unwanted distortion, I think you will be ok, but I would go plug into one if you can and test it, there is nothing like real world testing to find out.
the fact that you have a 150 watt head running out to a 160 watt cabinet like has been said should work, but I would want to go crank it up and see what you have, I play live and we crank it up pretty loud, again testing it is your best bet.
Matt
Create an account
Register a new account
Sign in
Sign In Now
