boydtee Posted February 23, 2015 Share Posted February 23, 2015 Hello, I purchased the G30 wireless set a few weeks ago new on Amazon. I've probably put close to 4 hours total play time with the device. Today something strange happened and the belt unit started blinking repeatedly both the Amber and Blue lights over and over again. After turning it on and off I can sometimes get it to restart normally with the blue light blinking twice but after a few min. it starts blinking both the Amber and Blue light again. I'm sure these lights are trying to tell me something but I can't find any documentation describing what they mean nor what to do. Any info that can be shared will be great. Thanks Quote Link to comment Share on other sites More sharing options...
dboomer Posted February 23, 2015 Share Posted February 23, 2015 Probably flashing an error code. With the power off put it on channel 6. Then power it on and slide the channel selector switch all the way back and forth 3 times. If that doesn't clear it you will need to return it for service. Quote Link to comment Share on other sites More sharing options...
boydtee Posted February 23, 2015 Author Share Posted February 23, 2015 Thanks for the advice. I'll try it tonight and see if this works. Quote Link to comment Share on other sites More sharing options...
shredacuda Posted August 12, 2015 Share Posted August 12, 2015 I called in with this same issue and was told it couldn't be repaired. He told me I had to get a new one Quote Link to comment Share on other sites More sharing options...
chadboney Posted April 9, 2018 Share Posted April 9, 2018 I am having the same issue with my new G30. It started up just fine when doing a sound check and than when I went live it wouldn't do anything but blinking lights. Is there something that I need to do to fix this issue? Quote Link to comment Share on other sites More sharing options...
billinbrasil Posted May 18, 2018 Share Posted May 18, 2018 Same problem. Anyone have a fix?? Quote Link to comment Share on other sites More sharing options...
AfiPlaysBass Posted June 10, 2018 Share Posted June 10, 2018 On 5/18/2018 at 6:30 PM, billinbrasil said: Same problem. Anyone have a fix?? Same problem fo a unit that I just bought three days ago. LIterally. I'm trying to see whether my cords are causing the error, but it would be nice if LIne 6 would address the issue since so many of us are posting about it! Quote Link to comment Share on other sites More sharing options...
Tornato Posted June 22, 2018 Share Posted June 22, 2018 I also have a G30 that flashes. Works for a minute then starts flashing? HELP! Quote Link to comment Share on other sites More sharing options...
littleeden Posted February 24, 2019 Share Posted February 24, 2019 I just posted about the same problem here: If I get any joy from the support ticket I opened, I'll post it here as well. Quote Link to comment Share on other sites More sharing options...
littleeden Posted February 24, 2019 Share Posted February 24, 2019 On 2/23/2015 at 7:26 PM, boydtee said: Thanks for the advice. I'll try it tonight and see if this works. Did it? Quote Link to comment Share on other sites More sharing options...
littleeden Posted February 25, 2019 Share Posted February 25, 2019 Well, according to the response to my ticket (very quick, thanks), it’s a hardware problem that needs a tech to look at it, and I should take it back to where I bought it. So that’s what I’ll do. Quote Link to comment Share on other sites More sharing options...
littleeden Posted February 27, 2019 Share Posted February 27, 2019 (edited) Swapped out for new without question by Professional Music Technology in Old Street, here in London. Can’t fault the service from them or Line 6, thanks. Edit: And if anyone's interested, the new one performed faultlessly at last night's gig. So if anyone gets the same problem, my advice is don't mess about - take it straight back to your dealer. Edited March 2, 2019 by littleeden Updated with new info Quote Link to comment Share on other sites More sharing options...
dboudah Posted March 8, 2020 Share Posted March 8, 2020 From Line6: Hi there, I'm sorry about the trouble with your Relay G30 unit. The purple light indicates "On channel change" and the amber/orange light on the Audio signal indicates "On power / channel change." It looks like it's stuck in the middle of a channel change. I suggest to try changing channels to see if it makes a difference, also try changing the batteries. If none of that works unfortunately we do not repair G30 systems. If they fail under warranty, they just get replaced. If you do buy a new transmitter it should work. The firmware update only allows it to be able to switch to RF2 mode, so if you get a new unit all you have to do is switch it to RF1 so it will work with your unit. Let me know if you have any other questions, thanks. Best regards, Jelena Line 6 Support Quote Link to comment Share on other sites More sharing options...
