samsc Posted July 1, 2013 Share Posted July 1, 2013 I am wanting to record my POD as a wet and dry signal on recording track 1 and 2 of my DAW. Is this possible? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 1, 2013 Share Posted July 1, 2013 Yes. Here is a preset I created some time ago to do exactly this: http://line6.com/customtone/tone/217206 Quote Link to comment Share on other sites More sharing options...
samsc Posted July 1, 2013 Author Share Posted July 1, 2013 Many thanks! Quote Link to comment Share on other sites More sharing options...
sulkbooth Posted July 2, 2013 Share Posted July 2, 2013 Or, you can use stereo out (both lef&right) for your wet tone, and setup the SPDIF to be dry out. (this implies that you have SPDIF in on your audio interface, of course...) If you use the HD500 as audio interface also, you would have to use the method as Silverhead described. Quote Link to comment Share on other sites More sharing options...
bjnette Posted July 2, 2013 Share Posted July 2, 2013 Or you can record both Dry on the s/pdif and wet thru the usb interface or line outs of the HD500 to the interface's line input rather than another pre amp input. It is still possible on a preamp input if it is turned right down. Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 2, 2013 Share Posted July 2, 2013 Or you can record both Dry on the s/pdif and wet thru the usb interface ......... I don't think you can use the HD500 usb connection as the audio interface and also use a second audio interface (for the s/pdif). The HD500 uses ASIO and I'm pretty sure the ASIO protocol requires that it be the only audio interface in use at any one time. Some non-compliant so-called ASIO interfaces (like ASIO4ALL) will permit you to use additional device(s) but they are known to cause problems with true ASIO devices like Line 6 products. Quote Link to comment Share on other sites More sharing options...
bjnette Posted July 10, 2013 Share Posted July 10, 2013 Okay you might be right there silvertone, it has been a long while since I used the HD' usb interface for recording. That leaves analogue thru an interface and its s/pdif. Quote Link to comment Share on other sites More sharing options...
Melodyshine Posted July 10, 2013 Share Posted July 10, 2013 You could use the looper for recording dry and wet. Quote Link to comment Share on other sites More sharing options...
jooshy58 Posted July 12, 2013 Share Posted July 12, 2013 Yes. Here is a preset I created some time ago to do exactly this: http://line6.com/customtone/tone/217206 what exactly is going on in that patch i have an hd pro??? Quote Link to comment Share on other sites More sharing options...
silverhead Posted July 13, 2013 Share Posted July 13, 2013 Use this patch converter to create the corresponding HD Pro patch: http://www.jzab.de/content/pod-hd Quote Link to comment Share on other sites More sharing options...
