tochiro Posted March 26, 2015 Share Posted March 26, 2015 Hi, About two years ago people here helped me create a controller to switch all the FXs off/on with the touch of a soft button. I don't need this controller any more but I cannot find how to delete it. Can you help me? Thank you. Cheers Quote Link to comment Share on other sites More sharing options...
Rewolf48 Posted March 26, 2015 Share Posted March 26, 2015 If you mean that you have a switch on the HD500 programmed to turn on and off a group of effects at the same time, then: Each Effect (and Amp) has a single foot-switch assignment; and this can be to FS1 through FS8, the Expression Toe Switch or None which match the label on the physical switches. To change the assignment select the effect and then press and hold down the ENTER button, then either press the switch you do want to assign, or turn the 1st editing knob to the one you want or None. While in this mode you can navigate to other effects/amps and change their assignments as well. It is in section 3 of the Advanced Guide under "Assigning an FX or Amp Block to a Footswitch" Quote Link to comment Share on other sites More sharing options...
