Charlie_Watt Posted April 1, 2015 Share Posted April 1, 2015 I keep my pod under my desk and it's a PIA to go down there and twiddle knobs. Is there a way to access the new global EQ with Edit? Quote Link to comment Share on other sites More sharing options...
KFURIO Posted April 1, 2015 Share Posted April 1, 2015 I don't think you can...which makes no sense to me. I believe you have to access the Global EQ through the unit. Hold down the VIEW button for a second and then scroll until you see Global EQ. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted April 1, 2015 Share Posted April 1, 2015 Nope. Global EQ is a system-level setting. As with other system-level settings, it doesn't appear in HD Edit. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 1, 2015 Share Posted April 1, 2015 I don't think you can...which makes no sense to me. I believe you have to access the Global EQ through the unit. Hold down the VIEW button for a second and then scroll until you see Global EQ. I think it makes total sense to not have your Master Volume and Master EQ accessible from EDIT, Plus, I am going to point out... and it may just become a new line in my signature... If you are going to design patches, you should be designing them with the Master EQ off. Quote Link to comment Share on other sites More sharing options...
Digital_Igloo Posted April 1, 2015 Share Posted April 1, 2015 If you are going to design patches, you should be designing them with the Master EQ off. If you plan on sharing those patches with others, absolutely. Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted April 1, 2015 Share Posted April 1, 2015 If you are going to design patches, you should be designing them with the Master EQ off. If you plan on sharing those patches with others, absolutely. You are correct. The first time I said it, I did specify "sharing with others". I just omitted that line this time. Quote Link to comment Share on other sites More sharing options...
