WynApse 0 Posted April 25, 2015 Received my brand-new POD Studio UX2 today. Followed directions and downloaded the latest POD Farm software, installed, the monkey software shows everything is fine, the licensing is all fine. Had problems with Reason Limited, and a support email in to them, but figured I could at least play with the interface stand-alone. Plugged it into a USB2 port on the back of the PC... heavy-duty machine, no problems there (it's what I do for a living).. Everything lights up and appears fine... except: I plug a guitar into either port, and the meter shows nothing. No amount of turning knobs on the device or the guitar changes anything. For reference, I've used 2 guitars and 3 cables, none of which have problems with a real amp. So I guess my question is... independent of the PC sound recording/playback settings, shouldn't I be able to plug a headset into the Headset output and a guitar into one of the inputs and as long as the device is powered via USB, I should be able to play and hear myself, right? I'm expecting this to be something stupid, so somebody help me pull my head out here! Thanks! -Dave Quote Share this post Link to post Share on other sites
TheRealZap 7,367 Posted April 25, 2015 you have to go into the control panel or system preferences and tell the meter what you want it to show.... it can be set to different things... inputs and outputs etc. Quote Share this post Link to post Share on other sites
WynApse 0 Posted April 25, 2015 Well, ok point taken, I'll look at that but... I didn't clearly state it in the message, but the title does... I get no audio out of it. I set my default recording device to be the Line 6 device, and the default playback device to be the Line 6 device, and I plug a headset into the POD Studio for good measure. At this point, after 4 hours of messing around with it, I may as well throw the cord from my guitar on the floor, and the plug from my headset next to it and play hoping I'll hear something... that would work as well as the POD Studio UX2 as far as I can tell. Quote Share this post Link to post Share on other sites
TheRealZap 7,367 Posted April 25, 2015 you should at least hear sound when playing youtube etc.... there shouldn't be much to it... have you ran and installed monkey to make sure you have the latest drivers? reboot? try different usb port? Quote Share this post Link to post Share on other sites
WynApse 0 Posted April 25, 2015 Ok funny that you asked those questions. First I closed POD Studio and re-opened it. Then I changed USB ports. Then I rebooted. Then I used the Install Monkey and re-installed the software and firmware. Then I closed and re-opened POD Studio about 10 times. Then I changed guitars. Then I changed guitar cords three times. So YouTube huh... had not tried that, but I did just now and it works. What I play on the PC goes through the device to the headset output. Back to the default recording device settings: it is set to Line 6 UX2, open properties, everything looks ok, go to Levels, there's the button to generate a tone I suppose so you can check balance/etc... can hear nothing. Went into Help->Hardware and Driver Settings->Input & Recording tab and set the meters to show output... meters work when playing YouTube. Switch to Input, and they're as dead as a hammer. More thoughts on getting from my guitar into this thing? Quote Share this post Link to post Share on other sites
TheRealZap 7,367 Posted April 25, 2015 by pod studio i assume you mean pod farm.... it has separate settings in it as well. it is possible that its a hardware issue and an exchange might help... it is rare though. Quote Share this post Link to post Share on other sites
WynApse 0 Posted April 25, 2015 Yes... POD Farm is the software and it has the settings and has been restarted multiple times, as well as the device itself being unplugged and plugged back into various USB ports. I just tried using Line 6 Monkey V 1.70 to "Reinstall latest" firmware, and got this error: UX2 update failed. (Code 800715 Firmware verify failed. PLEASE turn the device OFF and on again. Try the update again, making sure the cables are still connected. but... unplugging the device and plugging it back in, I get the same error although the firmware shows green a v 1.02 output still works, still have the input problem. If hardware issues are rare, and there IS a signature on the bottom that someone checked this before it went into the box... any other thoughts on what I could do? Quote Share this post Link to post Share on other sites
TheRealZap 7,367 Posted April 25, 2015 just stating the obvious here... but have you turned up the tone direct monitoring knob? have you tried recording? just to see if it will record even if you cant hear it? (that might mean a monitoring setup issue) Quote Share this post Link to post Share on other sites
WynApse 0 Posted April 25, 2015 I assume you mean the tone direct "Output" ? Yeah... spun that all around... nothing Recording... well.. as I said in my first post, PropellerHead says my software key has been used by someone else, which from what I can see on the forums is a common issue, so have not been able to run that. I downloaded Reaper as a stopgap ... I'll see if I can figure out how to do something through that Quote Share this post Link to post Share on other sites
BigChas52 2,546 Posted April 25, 2015 One more thing to check . . . Open up the "Mixer View" tab in POD Farm 2 and make sure that the inputs are set to "Instrument" Quote Share this post Link to post Share on other sites
WynApse 0 Posted April 25, 2015 BigChas52... You get to pick one of the teddy bears from the upper row! That was it... not sure I'd ever looked at that option, so thanks! whew.. Quote Share this post Link to post Share on other sites
TheRealZap 7,367 Posted April 25, 2015 good catch! :) i dont usually use pod farm standalone, so i don't often think of those options.... do all the input control from my DAW. Quote Share this post Link to post Share on other sites
tikus 0 Posted May 1, 2015 Since a week I have UX2 with POD Farm 2.57. All drivers & Asio installed.I can hear the sound of my guitar, but none of the Amps + Effects are working.How to fix this problem?Can anyone help me? Much thanks in advance! Quote Share this post Link to post Share on other sites
the7ths0n 0 Posted September 20, 2019 BigChas52... just wanted you to know 4 yrs later you are still helping people. i had the same problem... stumbled onto this thread and your advice solved my problem. kudos Quote Share this post Link to post Share on other sites
astried 0 Posted May 31, 2020 (edited) Setelah saya uninstal laptop saya, dan kemudian menginstal pod pod 6 ux2, semua suara menjadi Noise yang sangat keras. saya menggunakan windows 7 32bit sebelumnya, terkait kapasitas hardisk kurang memadai, kompilasi saya mengupgrade kapasitas hardik menjadi 2 terabites, dan mengatakan instal ulang pod farm, semua manjadi rusak, solusi adakah saya dari bandung indonesia contoh suara pod farm yang telah saya upload ada di youtube chanel : kanditapro (yang ada logo bergambar anak saya yang bernama agniya putri kandita) Edited May 31, 2020 by astried Quote Share this post Link to post Share on other sites
