npauly Posted April 27, 2015 Share Posted April 27, 2015 Hi, I have a copy of POD Farm 2.5 that came with my UX2. Is it possible to use this software with a Blue Yeti USB microphone? Quote Link to comment Share on other sites More sharing options...
BigChas52 Posted April 27, 2015 Share Posted April 27, 2015 I'm not familiar with the Blue Yeti, but it depends on whether the Yeti uses an ASIO driver. POD Farm 2.5 needs to see devices via ASIO. Note that you will still need to have the UX2 plugged in, as your copy of POD Farm depends on your UX2 for licensing. Quote Link to comment Share on other sites More sharing options...
Triryche Posted April 27, 2015 Share Posted April 27, 2015 The license that comes with the UX is hardware enabled and will only work with the UX or within a DAW as a plug-in while the UX is connect. To BigChas's point, the Microphone would need to be ASIO compliant and you would need to you purchase a POD Farm 2.5 Hardware Independent license to have POD Farm recognize the mic.. But you could capture the signal from your mic into your DAW and use the POD Farm plug-in. Quote Link to comment Share on other sites More sharing options...
