corywong Posted April 30, 2015 Share Posted April 30, 2015 is there a way to easily dump all my settings and presets from one M9 to another? midi cable? help! thanks! Quote Link to comment Share on other sites More sharing options...
corywong Posted May 13, 2015 Author Share Posted May 13, 2015 bump...? Quote Link to comment Share on other sites More sharing options...
PetGerbil Posted May 13, 2015 Share Posted May 13, 2015 I would try the Midi cable idea first, Connect a Midi cable from the Out to the In of the M9 you want to recieve. (You may need two cables, out to in and in to out for it to work.) Do a system dump from one into the other. In the Midi settings,go to "Midi Dump all ?" then press "On/off" to send it. (I've got an M5 so it may be different, but there is a typo in the manual for the M5 which says "Press Tap to send" when it should say "press On/Off" to send.) Or If you have a Midi Interface, You could use software such as "Midi-Ox" to record a "Sysex" dump of the M9's presets, and squirt that back into the other M9. (If you do use "Midi-Ox", you have to "Send/recieve" the data.Not just "Send" it, else it won't work. ) hth :) Quote Link to comment Share on other sites More sharing options...
