mathkampf Posted May 9, 2015 Share Posted May 9, 2015 Hi. My new fx100 just arrived. I've tried to use expression pedal, and what Im notice from the beginning, is that the expression pedal not working good. Its not working full travel. From heel position when mi moving it, its not responsing at all. From the middle position the toe working good. I tried recalibrate it-and the display shows 00 until its in the early middle position. After that Point, the Values changes. Does this is normal, or mine fx100 is not ok? Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted May 10, 2015 Share Posted May 10, 2015 That's not how it's meant to be, you could try a factory restore, check that you have the latest firmware and your app is up to date, I see you already tried to recalibrate, I thought that would have fixed it to be honest, sounds like a faulty unit Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted May 10, 2015 Share Posted May 10, 2015 What have you assigned to the pedal... volume, or wah? If it is volume it could be that a parameter needs adjusting. I don't own this unit so it's just a guess. I'm sure some one else will chime in. Best of luck mathkampf. Hi. My new fx100 just arrived. I've tried to use expression pedal, and what Im notice from the beginning, is that the expression pedal not working good. Its not working full travel. From heel position when mi moving it, its not responsing at all. From the middle position the toe working good. I tried recalibrate it-and the display shows 00 until its in the early middle position. After that Point, the Values changes. Does this is normal, or mine fx100 is not ok? Quote Link to comment Share on other sites More sharing options...
mathkampf Posted May 11, 2015 Author Share Posted May 11, 2015 Thank you very much for your help. Once i get USB cable (line6 not selling amplifi fx100 with), I'll flash new firmware and try to recalibrate, Then post if it worked. ;) Quote Link to comment Share on other sites More sharing options...
kalyabochek1979 Posted December 17, 2017 Share Posted December 17, 2017 Hello. I wanted to share the same problem. I can not calibrate the expression pedal. I do everything as in the video on the support site, but after pressing the pedal (when "01" is lit on the screen), "02" does not light up. will tell me what to do? Quote Link to comment Share on other sites More sharing options...
