famepot Posted May 9, 2015 Share Posted May 9, 2015 This is the third time this has happened. I've had two xd-v70 and one xd-v55 handheld mics break in two. The 55 went last night. the battery compartment screws onto the transmitter section with a screw through a plastic piece. unfortunately the battery cover screws onto the battery compartment, so a little tension on one half or the other, snaps the mic into two pieces. The only thing holding the two parts together is the plastic piece that the screw goes through. So if the mic is on a stand in the mic holder at the battery covering, pulling down slightly on the capsule end of the mic will snap the mic in two, or if the clip is near the power switch, slight pressure to the battery compartment end will also snap the mic in two. The plastic piece that the screw goes int, is not strong enough to resist any pressure. The first time, I figured it was a fluke, but the second time a female singer put her hand on the mic near the capsule while it was in the holder, and snap, two pieces. It pulls the ribbon cable and the molex connecter right out with it. The only way to fix them is to either glue the plastic piece back on and re-assemble, or replace the plastic piece which has the round circuit board on it, but this piece doesn't seem to be available. So twice, I've had to spend $200 on a new mic. See pic, after I've glued the small round plastic piece that the screw goes through back on. Waiting for it to dry completely before I re-assemble. Don't know if this has happened to anybody else, but the design is not good, and its happened to me three times not, so I gotta assume this has happened elsewhere. I've got another brand, that's ten years old, and has taken way more abuse, and never had a problem. Quote Link to comment Share on other sites More sharing options...
wilson69978 Posted May 9, 2015 Share Posted May 9, 2015 Wow, all I can say is don't let it happen a third time. Quote Link to comment Share on other sites More sharing options...
eklynx Posted May 11, 2015 Share Posted May 11, 2015 That happened to my V75 handheld this last christmas; It looks like the battery cover is also meant to be part of the strength, so if you have a cracked battery cover (the cylindrical that you screw on) you have a weakened structure and need to be extra careful (and replace the cover). When mine gave out it actually cracked the PCB with the battery contacts, so i had to replace that as well. Here's my link to my part numbers for a DIY replacement. http://line6.com/support/topic/12653-spare-parts-for-handheld/ I purchased all the parts through Full Compas 1 Quote Link to comment Share on other sites More sharing options...
Reason413 Posted May 15, 2015 Share Posted May 15, 2015 why on earth would you put a wireless mic in the clip like that??? I dont care what wireless company it is, the mic is most vulnerable in the battery cup area... the transmitter itself is Rock solid ( where the buttons are ) the mic should be in the clip up there.. You can replace the battery half with this http://www.fullcompass.com/product/428836.html and dont use " glue " in the future, us JB weld.. its the strongest and easiest to work with... if you still have your broken ones let me know, I may be interested in buying them from you Quote Link to comment Share on other sites More sharing options...
ceddiy Posted May 16, 2025 Share Posted May 16, 2025 Indeed, this has happened to me on 3 of the mics I have. I've repaired them 2 each. It's an engineering flaw. also, the ribbon cable was mangled irreparably, and I ordered a few from Full Compass. Not a stock item, but after 3 weeks, it's on it's way. I only have one mic usable because in it's case the ribbon cable survived. The power connector ripped off, but was easily repaired. The last repair I used cyanoacrylate with sodium bicarbonate on that plastic attachment "bump" where the screw goes through and It's now tougher than the rest of the plastic for sure. We'll see. Quote Link to comment Share on other sites More sharing options...
