triaxis Posted May 28, 2015 Share Posted May 28, 2015 do i understand it correct that not all the parameters are assignable to the (extra) expression pedal? Quote Link to comment Share on other sites More sharing options...
triggerhare Posted May 28, 2015 Share Posted May 28, 2015 Bear in mind that as I'm not a firehawk owner, just a potential customer my info could be incorrect, but it is my understanding that wah is solely controlled by the onboard pedal. Volume and all other "tweakable" parameters seem to be able to be assigned to the exp 2 pedal Quote Link to comment Share on other sites More sharing options...
BFrenzel Posted June 30, 2015 Share Posted June 30, 2015 Tap and hold on any parameter you wish to assign to the FX knob. You then have the option to assign it to the onboard pedal with a switch. If an external expression pedal is attached it will take over the assigned parameter. Some parameters aren't assignable because they wouldn't make sense or are just unusable. Just press and hold on various ones you want to assign. They are however just one parameter at a time. Quote Link to comment Share on other sites More sharing options...
bond19 Posted June 30, 2015 Share Posted June 30, 2015 Bear in mind that as I'm not a firehawk owner, just a potential customer my info could be incorrect, but it is my understanding that wah is solely controlled by the onboard pedal. Volume and all other "tweakable" parameters seem to be able to be assigned to the exp 2 pedal You do not need the external expression pedal to change the pedal to use an effect tweak, what will happen is you will control the effect (say, delay time) with the built in pedal, and will not be able to control volume. Wah will still engage when the pedal is depressed. Quote Link to comment Share on other sites More sharing options...
