bapurvis Posted July 4, 2015 Share Posted July 4, 2015 Hi All My expression pedal has stopped working for me, any ideas on how to trouble shoot this. Is this hardware? I have been trying to use this pedal and it no longer has any effect on my patches. Have been able to switch controller to variax volume or tone control and those work fine but expression pedal (exp1 or exp 2) seems to be dead. Try to reinstall flash memory but this had no effect. Any ideas? Thanks Found this and it solved my problem. f the Onboard expression pedal of the POD HD500 does not sweep through parameter values as it normally would, you may need to perform a pedal calibration to reset the functionality of the expression pedal:Hold the down the RIGHT ARROW button on the 4 Way Nav Pad while powering the unit on, until you see the “Test Mode†screen (Pedal Cal, etc.), and then proceed with the steps below: If not already selected, use on the 4 Way Nav Pad to select “Pedal Cal,†as shown above. Press the VIEW button. Set the pedal to the minimum “heel†position, then press the A footswitch to set a value for the Duty Cycle. You’ll see the value set to “100.†Set the pedal to the maximum “toe†position, then press the B footswitch to set a value for the Duty Cycle. Again, you’ll see the value set to “100,†as in step 3. Press the C footswitch to prepare for automatic selection of the Scaled Pedal Value and move the pedal from min. to max. You should see the Scaled Pedal Values read “0†at the heel position and “255†and the toe position. If you get values other than 0 and 255, power off and repeat these steps, starting at step 1. Press the D footswitch to save the settings. You’ll be returned to the Test Mode screen and the Pedal Cal item will show a “P†to indicated that the pedal calibration is complete! Power your device off and back on again to start using it. ***Please Note: Re-calibration of the POD HD500's expression pedal is necessary after performing a Global Settings reset. Instructions for how to perform a Global Settings reset is available here. 2 7 Quote Link to comment Share on other sites More sharing options...
atvcom Posted August 28, 2015 Share Posted August 28, 2015 Thank you, thank you for posting this!!!!! I was beginning to think it was hardware! Thank you!! 1 Quote Link to comment Share on other sites More sharing options...
hyrule_3333 Posted April 7, 2017 Share Posted April 7, 2017 I know this thread is old, but it was a lifesaver for me. My pedal was "expressing" correctly but the expression button was very finicky. (would only actuate one out of six times). I thought the button had gone bad. After doing the expression calibration, the expression button worked flawlessly. I didn't see anything regarding this particular issue, and I know some have complained of the expression button not working properly. 1 Quote Link to comment Share on other sites More sharing options...
subhamsamay Posted June 18, 2017 Share Posted June 18, 2017 I tried all the things. But scaled value remains 0 in both position. What to do? Quote Link to comment Share on other sites More sharing options...
tio_ghondronk Posted August 3, 2017 Share Posted August 3, 2017 saya sudah melakukan seperti yang ada di youtube..tetapi nilai skala pedal tetap saja 0 tidak berubah ke 225..lalu gimana? Quote Link to comment Share on other sites More sharing options...
Diegoniax Posted November 28, 2017 Share Posted November 28, 2017 Press the D footswitch to save the settings. You’ll be returned to the Test Mode screen and the Pedal Cal item will show a “P†to indicated that the pedal calibration is complete! Power your device off and back on again to start using it. My result is 'F' no 'P'. Please help! Quote Link to comment Share on other sites More sharing options...
djspleen Posted May 28, 2018 Share Posted May 28, 2018 Thanks! These instructions did the trick for me! Next time my expression pedal craps out AT a gig I'll know how to fix it right then and there. Quote Link to comment Share on other sites More sharing options...
Drickus Posted April 28, 2019 Share Posted April 28, 2019 thanx man this was very usefull!!!! Quote Link to comment Share on other sites More sharing options...
EmeryFry Posted October 14, 2019 Share Posted October 14, 2019 I've reinstalled the software, booting back to factory. I've done the calibration 3 different times, and after a few preset changes, the expression pedal goes out. The toe switch works, but the vol/wah does nothing. Could this be a ribbon cable issue? Also, the power off/right button step only works about 2 out of 5 times. I may just have a lemon Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 14, 2019 Share Posted October 14, 2019 26 minutes ago, EmeryFry said: I've reinstalled the software, booting back to factory. I've done the calibration 3 different times, and after a few preset changes, the expression pedal goes out. The toe switch works, but the vol/wah does nothing. Could this be a ribbon cable issue? Also, the power off/right button step only works about 2 out of 5 times. I may just have a lemon WHAT? There is no power button on the HD500. Quote Link to comment Share on other sites More sharing options...
EmeryFry Posted October 14, 2019 Share Posted October 14, 2019 unplug and replug while holding down the "RIGHT" curser. Not a power button Quote Link to comment Share on other sites More sharing options...
pianoguyy Posted October 14, 2019 Share Posted October 14, 2019 5 hours ago, pianoguyy said: but the vol/wah does nothing. you sounded like you know, but this statement makes me just want to make sure. It is just a general disclaimer that I say to everyone.... this is an expression pedal. it only does what you assign to it. even having a wah in your signal chain, you still need to assign it to the pedal. Quote Link to comment Share on other sites More sharing options...
EmeryFry Posted October 15, 2019 Share Posted October 15, 2019 yes, I know. I used to work for L6. This was my sample 500. I just started using it again and this problem occurred.. Quote Link to comment Share on other sites More sharing options...
hurghanico Posted October 15, 2019 Share Posted October 15, 2019 On 10/14/2019 at 4:59 PM, EmeryFry said: Could this be a ribbon cable issue? Could be.. there is a ribbon cable that connects the pedal to the main board.. the cable is connected via plugs (no soldering) but to prevent it from being accidentally disconnected it is secured in position even with hot glue .. it is unlikely that it can come off on its own due to vibrations, unless someone has previously unplugged it and removed the hot glue. _______________________________________________________________________________________________________________________________________________________________________ All about POD HD500/X help and useful tips 1 Quote Link to comment Share on other sites More sharing options...
