Jacksc5 Posted July 15, 2015 Share Posted July 15, 2015 To use four cable method should it be set to stomp or line at the back? I can't really get any overdrive from the amp in for cable method? Currently on line setting. I will try stomp tonight but if anyone knows the correct setup that would be handy. Thanks Quote Link to comment Share on other sites More sharing options...
phil_m Posted July 15, 2015 Share Posted July 15, 2015 Most effects loops on amps are line level, so I'd start there. Quote Link to comment Share on other sites More sharing options...
bond19 Posted July 15, 2015 Share Posted July 15, 2015 Line, and you want to use your amps distortion you will have to adjust the wetness of your effects loop, and make sure the effects loop icon is engaged in the app. Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted July 15, 2015 Author Share Posted July 15, 2015 Excuse my ignorance but is the mix in the app that control the wet/dry? I don't believe I have a switch on my amp. Using Ibanez TSA15H Quote Link to comment Share on other sites More sharing options...
bond19 Posted July 15, 2015 Share Posted July 15, 2015 If your amp does not have a wet/dry knob, then the only place you can do adjustments are the level in the effects loop button in the app. Quote Link to comment Share on other sites More sharing options...
Jacksc5 Posted July 15, 2015 Author Share Posted July 15, 2015 Excellent. Works a treat now. Moved mix up to 95% - 100% and amps overdrive shines through. Thanks people Quote Link to comment Share on other sites More sharing options...
