maurizioHorror Posted August 7, 2015 Share Posted August 7, 2015 My tap tempo will not work at all. Any fixes you guys know about. Help!! Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 7, 2015 Share Posted August 7, 2015 Was it working before and just quit working? Quote Link to comment Share on other sites More sharing options...
maurizioHorror Posted August 7, 2015 Author Share Posted August 7, 2015 Nope. I just bought it a week ago. Set it up. Easy. But the tap tempo won't work on any of the delays/modulation etc. also very noisey???? Quote Link to comment Share on other sites More sharing options...
phil_m Posted August 7, 2015 Share Posted August 7, 2015 Well, do you have the time/rate parameters on those effects set to a note value? If you have them set to a specific millisecond or Hz value, the tap tempo will have no effect on them. As far as the noise, what's your setup like? What do you have the M13 connected to? Quote Link to comment Share on other sites More sharing options...
JTSC777 Posted August 13, 2015 Share Posted August 13, 2015 bought new or used? if it is used the tap tempo/ has probably been hammered as mine was when I got it. soldered in a new switch and it has been good yes you must have the settings right or the tap function wont work Quote Link to comment Share on other sites More sharing options...
