porcytree Posted August 14, 2015 Share Posted August 14, 2015 Hey guys I want to get back to the default settings for my POD HD ( desktop version ) I had adjusted the EQ to allow for the " low end" of the amp I was playing through but have since got a new amp. As I had saved all my patches I decided to do a system reset to see if that got the default settings back ..... but stupidly didn't make a note of the settings prior to the reset so I'm not sure if the defaults were returned. Any help would be great thanks Porcs EDIT - factory reset does not set the global EQ back to defaults - just made a minor adjustment and reset my POD and the adjustment was not undone. Quote Link to comment Share on other sites More sharing options...
edstar1960 Posted August 14, 2015 Share Posted August 14, 2015 Here they are: Status Is ON (use ENTER to toggle between OFF and ON) 1) Band Select 3) Q 2) Frequency 4) Gain 1) LOW CUT 3) Blank 2) 20Hz 4) Blank 1) LOW 3) 0.7 2) 150Hz 4) 0.0 db 1) MID 3) 0.7 2) 1.8Khz 4) 0.0 db 1) HIGH 3) 0.7 2) 8.0khz 4) 0.0 db 1) HIGH CUT 3) Blank 2) 20.0khz 4) Blank Quote Link to comment Share on other sites More sharing options...
porcytree Posted August 14, 2015 Author Share Posted August 14, 2015 many thanks for that good sir Quote Link to comment Share on other sites More sharing options...
