frstrat Posted August 19, 2015 Share Posted August 19, 2015 I discovered that the set screw for my JTV-69 was missing. I've ordered a couple replacement screws from Full Compass but it's a special order item, and it'll be a few weeks to get the replacement. Anyone have any idea on the size/dimensions of this part? Wondering if I could find something at my local hardware store... Thanks! Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 19, 2015 Share Posted August 19, 2015 SET SCREW, 4-40 x .125", STEEL CUP POINT. Has to have the cup point or it won't lock the Trem bar correctly. Quote Link to comment Share on other sites More sharing options...
frstrat Posted August 20, 2015 Author Share Posted August 20, 2015 Thanks for the info! Quote Link to comment Share on other sites More sharing options...
Charlie_Watt Posted August 20, 2015 Share Posted August 20, 2015 Are you sure it's not metric? Quote Link to comment Share on other sites More sharing options...
psarkissian Posted August 20, 2015 Share Posted August 20, 2015 No,... it's inches. Thanks. Quote Link to comment Share on other sites More sharing options...
frstrat Posted August 25, 2015 Author Share Posted August 25, 2015 Ordered set screw with above noted dimensions - it was much too small. Perhaps I'm referencing the wrong part. I need to replace the screw accessible from the trem cavity that secures the arm to the bridge. Quote Link to comment Share on other sites More sharing options...
frstrat Posted August 25, 2015 Author Share Posted August 25, 2015 Full Compass says the dimensions for the set screw are m3x3mm, 1.5mm hex Quote Link to comment Share on other sites More sharing options...
johnmcchavs Posted June 23, 2021 Share Posted June 23, 2021 I ordered m3x3 and they are not matching (either the screw path is destroyed, or the screws are too large). Quote Link to comment Share on other sites More sharing options...
psarkissian Posted June 23, 2021 Share Posted June 23, 2021 Sounds like you ended up with the saddle height adjusting screw. See my prior posting for the correct one. Quote Link to comment Share on other sites More sharing options...
gtrman100 Posted June 24, 2021 Share Posted June 24, 2021 15 hours ago, johnmcchavs said: I ordered m3x3 and they are not matching (either the screw path is destroyed, or the screws are too large). Don't bother with it. Just get some plumbers Teflon tape, wrap the end, push it in, and it will fit pretty snugly. Quote Link to comment Share on other sites More sharing options...
