seibertdr Posted August 20, 2015 Share Posted August 20, 2015 I have a M9 that I used mostly for modulation some other effects. I also have a TC Electronic Nova drive that has a MIDI input. Can I use the M9 to change the presets on the Nova drive? Because of the layout, they are hard to reach to change the presets. If it can, how would iIsetup the MIDI changes. Thx, Quote Link to comment Share on other sites More sharing options...
kmoed Posted August 27, 2015 Share Posted August 27, 2015 I have a M9 that I used mostly for modulation some other effects. I also have a TC Electronic Nova drive that has a MIDI input. Can I use the M9 to change the presets on the Nova drive? Because of the layout, they are hard to reach to change the presets. If it can, how would iIsetup the MIDI changes. Thx, The Midi out on the M series pedals is crippled. It's only real use is for dumping your data out of the pedal. Why they did not implement a a proper midi out/thru on these is unknown and quite a shame... You can always get a separate midi controller, and an external midi merge box and control both units via the stand alone controller. Quote Link to comment Share on other sites More sharing options...
seibertdr Posted August 27, 2015 Author Share Posted August 27, 2015 Thank you kmoed. I kind of thought that was the case. It was really dumb not to implement full MIDI. How hard would that have been to do. Quote Link to comment Share on other sites More sharing options...
pepperman16 Posted May 5, 2016 Share Posted May 5, 2016 Hi, I use my M9 to control Ableton Live in my laptop, via midi . No problem to send midi messages Quote Link to comment Share on other sites More sharing options...
Rad_Randy Posted July 19, 2017 Share Posted July 19, 2017 Set each preset you want to use on the Nova to different MIDI channels. What the M series can do is send a channel change signal, but it can only do one channel per scene. On "scene setup" the lower right is MIDI channel number. When you select this scene, that channel number gets triggered by the Line6. So if scene1 is set for MIDI channel 1, and 2 for 2 etc, then your Nova has a sound programmed and saved to MIDI channel 1 and another to channel 2, then when you hit the footswitch to change to scene1, your Nova will do the program you set to MIDI channel 1, and when you go to scene 2, the Nova will do the program you set to channel 2 etc. Quote Link to comment Share on other sites More sharing options...
