Sign in to follow this
skykill3R
POD XT Live + POD Farm 1
Hello everybody.
I own a POD XT Live with all the Model Packs. I also bought back in the day POD Farm 1, which I was using so far to open my pod xt tones inside a DAW. Recently I clean installed windows 10 and downloaded the newest line6 monkey, where there is not an option to download again pod farm 1, but the only option is to purchase pod farm 2.5. So, i looked in the line 6 software download and found the latest pod farm 1 version (v1.12) which i downloaded and installed. But here is the problem. There is no way to authenticate it, since there is not an option of pod farm 1 in the final line 6 monkey release. So, when I try to load a tone preset which uses one of the amps or effects from model packs, I hear a clean sound, like the program stops processing everything.
Is there a solution to this problem? What should I do about it?
Thank you.
P.S. Of course I ran line 6 license manager and i checked that both my pod xt and PC are authorized. I also went to "my account" and i confirmed the model packs and POD Farm 1 in both "Purchase History" and "Software Add-ons" sections.
When the XTL is connected PF should detect that it has the model packs installed, IIRC the "About Tab" should show the packs you can use. When you boot the XTL up does it show all the packs on the opening screen? If you don't see the packs you will have to do the L6 License Manager again and make sure the packs show up there as installed.
One of the more knowledgeable fellas might be able to tell you what's up with your PF license. Who knows my man maybe they will upgrade you to PF 2 as you bought it once and now PF 1 is free.
this does not help. i have a 2006/7 pod xt live and it is NOT recognized by pod farm.
