Kip98 Posted September 17, 2015 Share Posted September 17, 2015 I want to use only the power amp of my marshall Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 17, 2015 Share Posted September 17, 2015 Run a cable from the Firehawk's 1/4" out to the Marshall's effects return on the back of the amp. It's as simple as that. Quote Link to comment Share on other sites More sharing options...
Kip98 Posted September 17, 2015 Author Share Posted September 17, 2015 So I plug my guitar into the guitar in port on the firehawk. What do I plug into the front of the Marshall? Anything? And what about the other ports. Thanks Quote Link to comment Share on other sites More sharing options...
mcbeddall Posted September 17, 2015 Share Posted September 17, 2015 You'll have nothing going into the front of the Marshall Just a cable from the firehawk 1/4 inch out to the Marshall fx return, then none of the eq knobs on the Marshall will work, only the master volume, all of your tone shaping will be controlled by the firehawk Quote Link to comment Share on other sites More sharing options...
Kip98 Posted September 17, 2015 Author Share Posted September 17, 2015 I got it. Thanks Quote Link to comment Share on other sites More sharing options...
Kip98 Posted September 18, 2015 Author Share Posted September 18, 2015 It works great with just 2 wires. One other question is about the position of the 2 push switches on the back. The output mode switch between line or amp should be where. Line just seems louder than amp mode. And because there are no wires coming out of the fx section, does it come into play Quote Link to comment Share on other sites More sharing options...
phil_m Posted September 18, 2015 Share Posted September 18, 2015 It works great with just 2 wires. One other question is about the position of the 2 push switches on the back. The output mode switch between line or amp should be where. Line just seems louder than amp mode. And because there are no wires coming out of the fx section, does it come into play The effects return on the Marshall is probably line level, so I'd set the switch to line. Quote Link to comment Share on other sites More sharing options...
Kip98 Posted September 18, 2015 Author Share Posted September 18, 2015 Thanks, this should help alot of people who first buy this. I love the firehawk. Quote Link to comment Share on other sites More sharing options...
