xeluaxeman Posted October 7, 2015 Share Posted October 7, 2015 hello going to buy a Digitec Jamman Stereo looper/phrase pedal and would like to know if there is no risk to connect the preamp out of spidervalve mk2 212 to the in of the pedal and the out of the pedal to the power amp in. the reason is so i could record a loop with different effects from the amp (clean for example) and play a live lead with other fx parameters (distortion... ) is it safe? thanks in advance Quote Link to comment Share on other sites More sharing options...
BillBee Posted October 7, 2015 Share Posted October 7, 2015 It should be fine, that's what the FX loop is for. Just be careful on how high the input to the Jamman is or you will get a lot of clipping. 1 Quote Link to comment Share on other sites More sharing options...
d0gmA Posted October 7, 2015 Share Posted October 7, 2015 That will work fine but you can switch patches while using the built in looper as well. Quote Link to comment Share on other sites More sharing options...
napynap Posted October 10, 2015 Share Posted October 10, 2015 That will work fine but you can switch patches while using the built in looper as well. Exactly, agreed, it works great. No need for external effects in the loop. The onboard preamp tones, clean, overdriven, distorted, effected, whatever, works well. Now if we can just find a way to disable the looper per patch... (excuse my sarcasm..it can't be done). Quote Link to comment Share on other sites More sharing options...
xeluaxeman Posted October 10, 2015 Author Share Posted October 10, 2015 thanks bros Quote Link to comment Share on other sites More sharing options...
