dickandsmithh14 Posted October 9, 2015 Share Posted October 9, 2015 So I looked in the manual and they said there is a hidden foot switch to change from EXP 1 to EXP 2. But for the life of me cannot find it. How do I activate it so I can switch from a volume pedal to a wah??? Quote Link to comment Share on other sites More sharing options...
aggravation Posted October 9, 2015 Share Posted October 9, 2015 push the pedal with your foot all the way in the toe down position. It might be a little too resistant at first and it probably has a tension adjustment screw to relieve some resistance if it doesn't break in and get easier after a few times. Thats the way the previous pedal was on the HD500 anyway. Look in the manual on the USB drive for details... Also, see if the manual mentions the switch is not 'live' if nothing is assigned to it...maybe you are triggering it but getting no results because there is no assignment made yet? Quote Link to comment Share on other sites More sharing options...
phil_m Posted October 9, 2015 Share Posted October 9, 2015 Well, it's deep within the chassis, so you're not going to actually see it. But it's under the toe of the expression pedal - it's definitely there. You actually don't feel much of a click when it goes, but it does take some pressure to activate it. I've also found that it helps if you put your weight back a little bit from the very toe end of the pedal. Quote Link to comment Share on other sites More sharing options...
