sijan92
Is DT-25 combo amp compatible with Line6 FB4 or FB2 foot switch?
Hi siijan92,
The FBV2 would be the only FBV foot switch thats compatible for the DT Series. Since the DT Series is only a two channel amp with no FX (other than reverb).
Yes, as long as the FBV2 is a dual latching type. I have a generic foot switch that works fine, doesn't even have labels! One switch toggles between amp A and B, the other reverb on/off.
It works best when amp A and B are the same amp model, and generally the same power settings. I use it with A and B both set up as Plexi bright. I match the settings on both, then I increase a touch of gain and volume to channel B, so it acts like a boost with a little extra grit
Along these lines..
https://reverb.com/item/495526-hosa-fsc-385-dual-latching-footswitch
https://reverb.com/item/578049-dual-channel-latching-foot-switch-kit-switch-input-signals-on-your-amp
