New Helix Preset test of Acoustic model
jaminjimlp
Put the "Taylor 314ce - Shure SM57.wav" IR (thats floating around here) @ #6 IR slot in Helix
here is the Preset it's called "Acoustic Chorus+" https://www.dropbox.com/sh/a6ja1ccg9opnsvu/AAANth50j9N_AJMVN2ykjfJua?dl=0
The way it is set up is that with EXP #2 when you move the peddle up or down it changes from Path #1 to Path #2 and the + is a very heavy tone so you can go from an Acoustic sound to a Hard Rock/Metal tone just moving the EXP #2 then there is a lead boost that swaps amps on FS #10.
Please let me know what you think and you can also help me dial in the Acoustic tone, I am really not a tweaker here is a short sample of the tone recorded straight in from Helix USB to PT12 no post processing.
https://soundcloud.com/neverforsaken/helix-acoustic-chorus-test
Edit: I forgot to add that you should use you neck position pick up for the acoustic and the bridge for the metal one.
sorry I had the clip in private I did this at about 4am
The Guitar used is a Fernandes Vortex Elite with an EMG 81 in the bridge position and the Fernandes Sustainer in the neck position.
Hey - I tried to preview it, but Soundcloud says: "
Sorry! We can't find that track.
Did you try to access a private track, but were not logged in?
Maybe the track has been removed."
.. I'd love to hear it.
Thanks!
Same here - can't access your track...
Thanks!
should work now
